| | diference between bicycle engines?!? Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. Does anyone know the difference performance wise between the wizzer 49cc 4-stroke and the 70cc 2-stroke??
I only ...  | |
04-22-2008, 11:02 PM
| | Motorized Bicycle Builder | | Join Date: Apr 2008 Location: NJ
| | diference between bicycle engines?!? Does anyone know the difference performance wise between the wizzer 49cc 4-stroke and the 70cc 2-stroke??
I only know this bout the 4-stroke and 2-stroke:
Engine type Air-cooled 4-stroke OHV single-cylinder
Displacement 49.1cc
Bore X Stroke 41.8 X 35.8 mm
Maximum Power Output 2hp(1.5kw)/ 6,800rpm
Compression Ratio 7.4:1
Carburetor Float Type
Ignition Transistorized Magneto
Starting System Recoil Pull-Start
Fuel Type Regular Unleaded Gasoline
Fuel Tank Capacity .5 Gal (1.89L)
Lubrication System Forced Splash
Oil Capacity 8.48 ounces (250ml)
Engine Oil SAE 10W30
Air Filter Semi-dry
Throttle Twist-Grip
Clutch Automatic Centrifugal
Transmission Shiftless Reduction Gearbox
Final Drive Chain-drive
2 Cycle / Air cooled
70 c.c.
30+ m.p.h.
Manual Clutch
Chain Drive
Thanks
__________________  Sean |
04-23-2008, 07:14 AM
| | Re: diference between engines?!? 50cc+4 stroke= slow and smooth.
67.5cc's+2 stroke= double the power, half the smoothness.
04-23-2008, 11:13 AM
| | Re: diference between engines?!? ok thanks
04-23-2008, 12:21 PM
|  | Senior Motorized Bicycle Builder | | Join Date: Apr 2008 Location: Valparaiso, IN
| | Re: diference between engines?!? A Whizzer engine 138ccs, not 50ccs http://www.whizzermotorbike.com/NE5Brochure.htm
You must be referring to some other engine.
As for the comparison- I will put my 49cc 4 stroke up against a 48cc 2 stroke on power- and I dare say, some 69 cc engine. In theory, 2 strokes have an advantage, but the difference between a Chinese 2 stroke and a Honda 4 stroke is more than how often the plug fires.
__________________ 3 cubic inches of raw power. |
04-23-2008, 02:31 PM
| | Re: diference between engines?!? Quote:
Originally Posted by HoughMade A Whizzer engine 138ccs, not 50ccs http://www.whizzermotorbike.com/NE5Brochure.htm
As for the comparison- I will put my 49cc 4 stroke up against a 48cc 2 stroke on power- and I dare say, some 69 cc engine.. |
You're on!
04-23-2008, 02:32 PM
| | Re: diference between engines?!? Sean, that's a standard frame mount set up some here run. Most run the two stroke.
04-24-2008, 01:01 AM
| | Re: diference between engines?!? wow wait where did the 138cc come from?! and aren't all a frame mount engine? I'm a little tired and confused been a long stressful night!!!
04-24-2008, 06:55 AM
| | Re: diference between engines?!? The "Whizzer" is a 138cc 4 stroke, the frame mount "wizard" is a China built 67.5cc two stroke. The Whizzer is built in Taiwan, the China-co. engines are built in China, a slight difference.
A Whizzer is 1600 bucks, a China-co. kit is 200.
04-24-2008, 09:30 AM
| | Re: diference between engines?!? oh ok, 138cc just seemed big for a bike... nevermind tho
__________________  Sean | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:54 AM. |
