Originally Posted by Pablo It doesn't work that way. Think about it. It still freewheels, even if we "weld" the rear freewheel. |
Ok Im confused on your problem then. I thought you were wanting to have the ease of start like we do normally with the gear on the left side. When you run a front free wheel and a rear free wheel you have to constanly pedal to be able to start the motor so if your going down a hill and you want to start the motor you have to pedal to start it because there is no movement of any of the drive line. If you have a fixed rear gear then when your going down that same hill you have movement of the drive line your pedals are not moving but everything else is just like it normally would if you are running a regular setup. Then you can just pop the clutch and go.
The schwinn system was made so that the rider could change gears when they were not pedaling with the fixed rear gear because the chain line was still moving but the rider didnt have to pedal.
So by welding the rear we just fliped the system that we use now. So with your setup and a fixed rear gear when you just push the bike the rear gear moves with the wheel it turns the crank and turns the jackshaft and motor just like it does on any other happy time setup. With the two free wheels that you have now its like turning over a model t.
