Clutch pads
Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. Who sells square clutch pads???...
Old 05-06-2009, 03:50 PM
Glenn M's Avatar
Default Clutch pads
Glenn
Old 06-17-2009, 12:54 AM
Default Re: Clutch pads
looks like the pads are worn out on my uncles happy time with over 3000 miles
where can i get replacement ones
Old 06-17-2009, 01:27 AM
OzzyU812's Avatar
Zoombicycles Motor Bicycle Gas Engine Kits Set of 15 Clutch Pads (3-8) | 15-Clutch and Throttle | 6-Parts and Accessories | RuiHong Enterprises Ltd.
DAX 80f
Slanthead
NGK B7HS
SBP performance wire
44T
Stock Exhaust
32:1 cheap oil
no port matching
30 mph uphill!!!
Old 06-17-2009, 02:14 AM
Junster's Avatar
Jim at Creative Engineering "Manic Mechanic" ad right side. Is getting ready to start distributing some that are made of a real quality friction material. If you can wait for them he said they'd be going for about $10.
Put something FUN between your legs..
Old 06-18-2009, 01:14 AM
OzzyU812's Avatar
he mentioned some mat'l a few weeks ago
DAX 80f
Slanthead
NGK B7HS
44T
Stock Exhaust
32:1 cheap oil
no port matching
30 mph uphill!!!
Old 06-27-2009, 04:18 PM
Yeah, I can't wait for Manic Mechanic's clutch pads. Mine are crappy and cheap. I can't wait for an upgrade.
Old 06-28-2009, 09:37 AM
Creative Engineering's Avatar
MANIC Mechanic
I finished the tool for the round pads a week and a half ago...at least I thought I did
I punched some out to test. Everything was going according to plan. These were punched based on the diameter of the holes in a gear I had on my desk from a dissassembled engine.
Sooo...I took the cover and pressure plate off of a customers' bike thinking I would test the new friction material. I knew his clutch used the round pads, because I have worked on it before. The holes in this gear are 1/16" larger than the one I went by.
Fortunately I designed the tool to have interchangeable punches and dies.
Unfortunately, before ordering, the customer is going to have to take the clutch apart and determine what size and shape they need.
I will make the punch and die set for the trapezoids as soon as I can test the material.
It seems like there is always something to throw you off track when dealing with these engines.
I wouldn't be the least bit surprised if there is even a third round size, and possibly several sizes of trapezoid.
The first 5 people to post pics on this thread of their clutch gear, being measured with calipers, will get a set to test.
I have friction material for a gear with .475" diameter holes for the pads ready to ship. If your gear has .535" diameter holes, or the trapezoids, there is no need to post a pic. I only have the one size available.
I need to get this going, but in the event the chosen material is wrong; I don't want a bunch of them out there.
I'm finishing up a batch of sprocket adapters, and intakes, so I will probably not get the chance to make the .535" tooling until the end of the week. Once I punch the 535's I can test the material on my customers bike.
Jim
Old 06-28-2009, 11:34 AM
So trapezoids should be done by the end of the week? SWEET.
It is supposed to rain all week, and I'm busy all week anyway.
  #9 (permalink)
Old 06-28-2009, 01:37 PM
Last year I made clutch pads from this material and it did not work no matter how I adjusted tension. Would have been nice at about half a dollar a bike. Ended up going back to the "tire sidewall" stuff.
McMaster-Carr
6175K161 Nonmetallic Molded Brake and Clutch Lining 5/16" Thick, 2" Width $7.37 Ft.
  #10 (permalink)
Old 06-30-2009, 05:20 PM
Banned
Jim
Jim
I will Priority Mail you some clutches to use as models along with the money for the intakes
I have Grubee trapezoidal shaped clutches and the round / PK / raw crap ones with the very uneven pads
please call me
Need some work? I have lots for you....
The 4 stroke is the future as the 2 stroke is the walking dead
