| | Clutch?!?! Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. First off - this is my first post so hello everybody!
My boyfriend has bought an engine kit from ebay and ...  |
04-18-2008, 12:54 PM
| | Motorized Bicycle Apprentice | | Join Date: Apr 2008
| | Clutch?!?! First off - this is my first post so hello everybody!
My boyfriend has bought an engine kit from ebay and has been fitting it today. There's been a few minor problems, which we're not too concerned about and can sort out ourselves, but this one really has us stumped.
The clutch lever (ie, the bit sticking out of the top of the engine itself) turns the wrong way. I understand that when the lever on the handlebar is pulled it should turn inwards. Ours will only turn outwards from the normal position (pointing towards the rear of the bike).
This is quite an issue, and we've been tinkering all day and reading articles and posts on here and still have no clue.
The other part of the problem is that even when it is turned out as far as it will go, the wheel cannot turn freely (ie, the engine in still engaged). When you pull it out there is some resistance though, it feels like it should, but it's going the wrong way and doing nothing.
Any ideas? It's all rather frustrating. |
04-18-2008, 01:09 PM
|  | Custom Builder / Dealer | | Join Date: Mar 2008 Location: Venice, CA.
| | Re: Clutch?!?! I can't think of any reason at all why it wouldn't turn inwards??
The way it's made, it will push the clutch pin whether you push it inwards or out.
You might need to tighten the clutch A LITTLE from the other side of the engine to disengage the engine from the wheel... |
04-18-2008, 02:23 PM
|  | Senior Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Bellingham, WA
| | Re: Clutch?!?! If you are attempting to do it by hand it is very difficult. One might think that it is jammed but it probably isn't. The spring in the clutch is very strong. I would just try a little harder. I have added a few pics to try and help. You should also go look at Normans post on motor teardown. bicycle engine total tear down
04-18-2008, 03:03 PM
|  | Amsoil Dealer | | Join Date: Dec 2007 Location: Duvall, WA PNW
| | Re: Clutch?!?! It is easy to see how it works....just take the engine sprocket cover off. I can't imagine this but maybe the cam on the levered shaft is bass ackward....somehow. Regardless it's really apparent how it should work when you take the cover off, because it comes off together. |
04-18-2008, 03:23 PM
| | Re: Clutch?!?! Welcome- when you get a chance, read this to help with set up for a long anf happy engine kit life- Bicycle Motor Preperation And Care
The guys are right, the lever will work whether it's going in or out, but it IS really hard to push by hand. I'd hook it up and see what happens.
Keep us posted!
04-18-2008, 03:27 PM
| | Re: Clutch?!?! I thought mine was broken but it was just hard to work by hand and I was a bit afraid to put any muscle to it. It will work itself out. The clutch lever with most kits is also a problem it never did work on my kit. I wound up using a brake lever |
04-18-2008, 03:50 PM
| | Re: Clutch?!?! Thank you!
Took it out, fiddled with it some more, put it back, read what you'd said, hit it very hard with a metal object and it MOVED! |
04-18-2008, 04:08 PM
| | Re: Clutch?!?! Now I just have to get it started... lol. |
04-18-2008, 06:24 PM
| | Re: Clutch?!?! I think one of my posts shows how to work the lever on the engine easily by using a vice grip pliers to work the lever on the engine. I do this to hook up the clutch cable as its easier for me move the lever in with the pliers as I thread the cable into the lever on the engine.
Good for you on your build I hope you get it running with out a lot of problems but if you don't let your fingers do the crying here we'll help ya. Pictures help sometimes and a big friggin hammer will relieve your frustrations but them you will have a pile of broken aluminum. That ain't cool
Norman
04-18-2008, 06:35 PM
| | Re: Clutch?!?! The motto here should be when in doubt ask.... Unlike the high priced spread people here want to help... | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | |
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Clutch Pucks | Easy Rider | Swap Shop | 13 | 06-01-2008 08:09 PM | | Clutch noise? | ran49 | Motorized Bicycle General Discussion | 7 | 04-15-2008 12:07 PM | | Clutch use Q's | TINKERER | Motorized Bicycle General Discussion | 16 | 03-27-2008 12:36 PM | | A clutch question | Big Joe | The Tavern | 2 | 03-23-2008 06:31 AM | | clutch lever | ran49 | Bicycle Engine Kits | 4 | 03-12-2008 06:33 PM | All times are GMT -5. The time now is 10:23 AM. |
