| Sponsors
| Our Forums | | | | 2 Stroke Bicycle Engines & Kits 2 stroke motorized bicycle engine kits need careful installation and setup, find out how from our professionals here! | China girl 4 cycling Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. My old original 80-66cc still stock with low miles still insists on 4 cycling @ part throttle and cruising. It's ...  | |
06-01-2009, 10:13 PM
|  | Motorized Bicycle Elite Member | | Join Date: Sep 2008 Location: Fl.
| | China girl 4 cycling My old original 80-66cc still stock with low miles still insists on 4 cycling @ part throttle and cruising. It's better warmed up. Works better at low rpms under load. I moved carb clip to top groove on needle and run 24:1 Do I need a longer needle? Smaller jet? or something else? Different carb? |
06-02-2009, 09:11 AM
| | Re: China girl 4 cycling That's fairly normal. If it breaks in and out of a four cycle when cruising with a light load, it's about perfect for these old school two strokes and perfectly normal.
If it runs at a four cycle all the time when under light load, go to a smaller jet, or solder the one you have closed and re-drill it a little bit smaller.
06-02-2009, 09:12 AM
| | Re: China girl 4 cycling You can also try opening up the exhaust (cutting the baffle a little) or opening up the air filter cover to allow the ebgine to breath a little more.
06-02-2009, 06:32 PM
|  | Motorized Bicycle Elite Member | | Join Date: Nov 2008 Location: Las Vegas NV USA
| | Re: China girl 4 cycling it would also be nice to see the plug chop to see the result. BGJ is right as well a good motor will cruise in and out of the "4cycle"
Ride it like you stole it! |
06-02-2009, 09:22 PM
| | Re: China girl 4 cycling Thanks everyone, I like the jet solder idea. Maybe being at sea level helps cause it more also. For the first mile or so it 4 cycles all the time. Also we've been having 80-90% humidity lately. |
06-02-2009, 09:39 PM
| | Motorized Bicycle Elite Member | | Join Date: Apr 2009 Location: MA
| | Re: China girl 4 cycling What does the term 4 cycilng mean when talking about a two cycle engine?
I recieved my first engine(80/66cc) and I have acouple of questions. First the chain, the rollers have about 1/32 travel side to side. Is this normal, seems that every other chain I've come across the rollers have min side play. Next question, The sleeve casting has a defect. You can see one of the piston sleeve bolts or bolt sleeve due to a air buble in the casting. I do not think it is a problem, but not sure? Thanks Russell |
06-03-2009, 10:08 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jan 2009 Location: Phoenix, AZ
| | Re: China girl 4 cycling Quote:
Originally Posted by Russell What does the term 4 cycilng mean when talking about a two cycle engine? | I would like to hear 4 cycling, I understand the concept, but just what does it sound like?
Map your motorized bikes location on a Frappr Map show us where you are and post a pic of your bike. If trailer parks didn't exist would tornadoes exist? |
06-03-2009, 10:18 AM
| | Re: China girl 4 cycling In order of asking-
Chain rollers with side play- "normal" for these kits.
Casting error- Usually not a problem, but some sellers will replace the cylinder or kit if you let them know about it.
Now, "4 stroking" or 4 cycling sounds like a rough stacatto or firing every other cycle, as opposed to a smooth ""buzz" of the 2 cycle sound. If your engine four strokes all the time, it's too rich.
When these ancient tech piston ported two strokes are "right on" with their mixture, they will break in and out of the two cycle/four cycle sound at cruise or light load, and break into a clean two cycle "buzz" when you twist the throttle, or start up an incline.
Part of the reason is the crappy carb, and part of it is the "ancient tech piston porting". If you have one that runs in a clean two cycle at cruise, you are getting close to a very lean condition.
06-03-2009, 10:43 AM
| | Re: China girl 4 cycling Thanks for the help!
Russell
So many projects so little time. If anyone invents a 36 hr day it would be a big help to me! |
06-03-2009, 12:39 PM
| | Motorized Bicycle Elite Member | | Join Date: Aug 2008
| | Re: China girl 4 cycling if you wanna open up the muffler, i could recomend cutting 1/2" off from the staight tube that lets the smoke out off the muffler....the one you can remover on the end of the muffler...cut cut until you feel better or you damage it lol... thats why 1/2"cuts are recomended. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 09:39 AM. | | |
