Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Bicycle Engine Kits
Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here!
Carburetor pictures how to install and rebuild
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. I also want to know what the tube on top of the intake is for. looks snazzy....
  #31 (permalink)
Old 06-23-2008, 06:43 PM
Motorized Bicycle Apprentice
Default Re: Carburetor pictures how to install and rebuild
  #32 (permalink)
Old 06-23-2008, 06:48 PM
Boost Bottle connection...
  #33 (permalink)
Old 06-23-2008, 08:57 PM
Norman's Avatar
LORD VADER Moderator
it was for a bootle bottle which none of my bikes have anymore I now have one plugged and the other welded shut waste of money for a bottle get a pipe for the exhaust money better spent and you won't have to mess up your intake.
I make an adjustable bottle that would go from 10cc to over 100cc and used differant lengths of tubing along with bottle straight up and horz. with no gains it would idle slower and sort of smoother but then it would idle so slow that it would die and when off the throttle it took a while for it to come back down to idle. Hard to start when it was cold outside so I don't like them but some people do. I might still have a bottle laying around you pay the shipping and you can have it.
norms-iron-works.tripod.com
  #34 (permalink)
Old 07-18-2008, 09:37 AM
Quick question. How mych play should there be in the throttle cable. There doesn't seem to be any slack in the cable at all is that wrong?
  #35 (permalink)
Old 07-18-2008, 11:07 AM
I keep about 1/8".....
  #36 (permalink)
Old 07-18-2008, 01:04 PM
So I should get alonger cable? I have loosened at the handle and at the carb. I have given her all I got captin. lol
  #37 (permalink)
Old 07-18-2008, 02:01 PM
Bikeguy Joe's Avatar
If it idles O.K., you won't nned the longer cable.
  #38 (permalink)
Old 07-22-2008, 11:10 PM
eDJ's Avatar
eDJ eDJ is offline
Ya know I've never owned anything that had a carb with a "tickler". So, is it just a way to prime the engine by depressing the float to allow more gasoline into the carb ? It seems like it would create a condition like slightly flooding the engine a bit so you have a rich start condition.
When I was a kid there were some older guys with Cushmans and "Mustangs"
that I would see reach down and hit a "prime" two or three times before kicking
the starter. I once watched this guy who had recently purchased one of these old bikes and was kicking himself numb. I'm with my mom and at like five years of age point out to that part of the carb (as I'd seen these other guys press on it a few times) and the guy looks at me dumbfounded. So he does it and kicks the starter and it starts. He pulled out looking at me in shock.
So.....is this tickler a primer or what ?
  #39 (permalink)
Old 07-25-2008, 07:46 AM
Default Re: Carb pictures how to
Hi Norman, Can you tell me the best way to adjust the throttle adjustment area? I put a new carburetor on last night. That made my leak go away but I have lost a lot of power. I tried screwing the throttle cable at the carb in more but it only made it worse. Now I'm thinking of going the opposite way.
Can you give me any helpful hints on this?
I would sure appreciate it!
thanks,
john
[quote=Norman;1215]pen pointing to an adjustment area for taking up slack on the throttle #2 pic my throttle cable has another adjustment up at the twist grip to take the skack out of the throttle cable.#3 all done. #4 its running and its cold .
Thats it hope your questions got answered if not give me a PM.
Norman
70cc HT
Moon Dog
crabdance@gmail.com
  #40 (permalink)
Old 07-25-2008, 09:41 AM
Norman's Avatar
to take the skack out of the cable lengthen out those areas. what this does is make the outter housing longer in relation to the inner cable.
