carb throttle connection, just need to make sure.
Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. I got the engine on my bike today, with the exception of making the mistake of getting a Bell Chainbreaker ...
Old 05-28-2009, 08:48 PM
Default carb throttle connection, just need to make sure.
I got the engine on my bike today, with the exception of making the mistake of getting a Bell Chainbreaker from walmart and expecting it to work ( so I still need to shorten my chain lol )... everything except the clutch and chain are hooked up.... but the throttle connection is what had me confused.. I pulled out the needle and the barral out of the carb.. pushed the cable thru the spring and then latched it in the groove on the bottom of the needle/ barrel assembly and then put it togther... I guess it's ok, throttle doesn't have much movement and it doesn't return on it's own but it deffinetly moves like it should inside.. did I do it right? it's been a while since I took apart a motorcycle carb, when I did, I left everything connected.
Old 05-28-2009, 09:33 PM
misteright1_99's Avatar
Default Re: carb throttle connection, just need to make sure.
Post #5 shows a good pic of the assembly order. If it doesnt return smoothly, maybe the top cap is screwed on too tight.....
Carburetor pictures how to install and rebuild
Old 05-28-2009, 11:17 PM
Shadeslay's Avatar
Sounds like you might have the slide backwards. Make sure to line up the dimples in the carb to the grooves in the slide. If that's not it check your cable to make sure it's not binding somewhere. One way would be to unscrew it from the carb and see how the throttle responds.
Sun Tzu: To secure ourselves against defeat lies in our own hands, but the opportunity of defeating the enemy is provided by the enemy himself.
Old 05-28-2009, 11:20 PM
It's smooth, but it just doesn't return on it's own.. then again, the stock twist grip has no return spring.. and the grip doesn't twist much.. pictures looks like it's togther right tho
Old 05-28-2009, 11:22 PM
I used the indendtation for the idle screw to line up the slide.. throttle disconnected, everything works good.. when I unscrew the top off of the asselbly and pull the cable/ slide out, the slide tilts to the side because of the spring tension, could that be happening inside the carb causing any of the problems?
Old 05-28-2009, 11:26 PM
Cabinfever1977's Avatar
your cable might be binding dont tie the cables to the bike tight or tight angles.
these cheap throttles dont return all the way on there own,sometimes you have to twist them the other way to return to idle.
the throttles do twist a full half turn easy,if not its binding somewhere.
Old 05-28-2009, 11:29 PM
Shadeslay's Avatar
That's normal without something to guide it. With it off the carb does the throttle still not spring back? If you still have problems with it when it's unscrewed from the carb, it's likely a cable issue.
Edit: As mentioned by cabin, don't expect to much spring back from these. I have had some success by adding a little oil inside the cable housing.
Old 05-28-2009, 11:32 PM
the cable is not tied up yet... it might be 1/2 turn but I'm not sure.. I think I'll take the top off of the throttle control thing, and see just how much it's pulling..
  #9 (permalink)
Old 05-28-2009, 11:35 PM
does the same thing... I didn't use any oil in the cable housing, but it still seems smooth when it's off, just no return.. what kind of oil should the housing get?
  #10 (permalink)
Old 05-29-2009, 12:21 AM
Shadeslay's Avatar
I used Singer machine oil, but anything similar would work fine. Got it at walmart in the sewing section for about $2. Go over your cable and make sure it's not bent or binding up somewhere. If you turn the throttle "or pull the wire" while holding the cable you can often feel if it is bent or rubbing.
