Can anyone diagnose this?
Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. Grubee Skyhawk 66/80 fires up fine, but no power. If I keep pedaling, it keeps chugging. Once I stop ...
Old 09-20-2009, 11:02 PM
Default Can anyone diagnose this?
Grubee Skyhawk 66/80 fires up fine, but no power. If I keep pedaling, it keeps chugging. Once I stop pedaling, it rapidly, but incrementally dies. If I pull the clutch, it dies immediately.
I'm stumped. Why would pulling the clutch make it die? Is it just the friction of me pedaling or going downhill that keeps it chugging?
I've disconnected and wrapped the kill switch wiring. The magneto seems OK. The clutch is engaging and disengaging. I got a new plug, but I think I'll check for spark again.
Old 09-20-2009, 11:04 PM
robin's Avatar
Default Re: Can anyone diagnose this?
I had something similar when the cdi coil went.
Old 09-20-2009, 11:33 PM
Yeah. Just took the wire off the plug and rode it - same symptoms.
Any way to fix the CDI, or is it just a replacement part?
Old 09-21-2009, 01:31 AM
I had what sounds like a simular problem....brand new motor had a striped head bolt....gasket leaked....fliped stud around (way more threads in block than nut) ....torqued head....fixed ... somthin to look at ......J
Old 09-21-2009, 02:03 AM
hiker472's Avatar
If it is the CDI, check to make sure the spark plug wire is twisted in tight enough......................I had this problem after putting on a high performance wire (for some reason) and ended up putting a hose clamp on the wire and wiring that to the frame to keep it from slipping out.
I know........totally jimmy-rigged, but hey, no more problems!
Don't feed the bears....
Old 09-21-2009, 05:51 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Get rid of the plug ins on the CDI wires, & solder & heat shrink them.
Old 09-21-2009, 05:53 PM
Kevlarr's Avatar
Also try unhooking your kill switch. There's been a few people that have gotten bad ones right out of the box.
Old 09-21-2009, 06:06 PM
Yah. Did that. I just went ahead and ordered a new CDI. I'll report back. I think otherwise, with as much troubleshooting as I've done, the bike is probably finely tuned.
  #9 (permalink)
Old 09-21-2009, 09:18 PM
GraingerDoodTim's Avatar
if i let gas into the carb before i am moving the bike will flood instantlly. so I just get going and then open the valve and viola runns like a dream. if i let the carb flood i get the same problem, wont run but does this weird sort-of-run while i am peddling. If i stop peddling it stops, and if i pull the clutch it also stops. I know how to remedy this probabally a stuck float or something, but really, i have spend so much time messing with this thing. Now i have convinced myself its an anti-thef measure cause you cant peddle it that fast>
  #10 (permalink)
Old 09-23-2009, 11:10 PM
3 things make a gas motor run air, fuel, spark...shut off your fuel spray carb cleaner into air filter...does it start and die quickly...if so its a fuel problem...get an inline spark tester...they arent very expensive...make sure you got a spark...if not you can hook a noid light up to the primary ignition and see if that flashes...hey is this thing new??? make sure that the connector is not attatched to the 6V wire...you said you replaced the plug right...was the plug wet???need allittle more info from you to help you...good luck...id like to hear about how you make out
