| | | 2 Stroke Bicycle Engines & Kits 2 stroke motorized bicycle engine kits need careful installation and setup, find out how from our professionals here! | Buyers Beware Of What You Get111 Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. I bought my 2 stroke from The LA SHOP, note their warrenty is only for 14 days! And i went ...  |
09-22-2009, 09:20 PM
| | Motorized Bicycle Senior Member | | Join Date: Apr 2009 Location: somewhere around you
| | Buyers Beware Of What You Get111 |
09-22-2009, 11:45 PM
| | Motorized Bicycle Elite Member | | Join Date: Feb 2009 Location: australia
| | Re: Buyers Beware Of What You Get111 Quote:
Originally Posted by the willi | Need a little more info bro, before you lash out again. The clutch is disengaged yeh? are you sure the pin and bearing is in there? is the clutch arm in the right position? How far does it move when ya pull the cable? Have you turned the flower nut?
How have you been riding it for 2 weeks?
09-24-2009, 12:25 AM
| | Re: Buyers Beware Of What You Get111 well to some up this the clutch had greese in it when i bought the kit, and i have everything adjusted just right , but my complaint is that the la shop only has has a two window on their products and i have been only riding my mb for two weeks. l have had my kit for one month now! and i ride my mb everyday back and forth to work! i have had five mbs now and this is the first one i have ever bought at the la shop. besides the clutch problem everything else workss, so have a great day yeh. later Willi |
09-24-2009, 01:28 AM
| | Re: Buyers Beware Of What You Get111 Man i got a crack in my casing that leaks out goo, i email the supplier and his responce...................... yeh you get the drift. bottom line CHINA. and 100bucks for you guys its a bargain grease or no grease. |
09-24-2009, 02:10 PM
| | Re: Buyers Beware Of What You Get111 Hey Willi... Don't "PM" me, call me! I'll get you hooked up! |
09-25-2009, 02:28 PM
| | Motorized Bicycle Member | | Join Date: Dec 2008 Location: jacksonville, florida
| | Re: Buyers Beware Of What You Get111 will....
the arm with greese in it is NOT the clutch. it is the clutch activation leaver.
the arm presses against a little pin and pushes the clutch pressure plate on the other side of the moter (under the large cover on the right side of the motor).
the actual adjustment is made by tightning or loosening the 'star' nut in the middle of the clutch plate.
be sure to put the little brass set screw in when done.
09-26-2009, 12:07 AM
be sure to put the little brass set screw in when done. | thanks bro, note i know how the motor works! i have had these motor all a part! thanks to alot of people! with the support! thanks to tdove , 2door , and venice boy, and a few others with all the effort! again thanks to everyone here at this site! not the other one!this site rocks later to all!    |
09-27-2009, 12:11 AM
| | Motorized Bicycle Elite Member | | Join Date: May 2009 Location: colorado
| | Re: Buyers Beware Of What You Get111 Willi I see in your 1st post you stated the motor came with a 14 day warranty then you said you rode it for 2 weeks then the problems started happening. Whats the issue with the vendor here? You knew going in there was only a 14 day warranty didnt you? I dont see any efforts stated on your part trying to work with the vendor to correct any problems. My point is that alot of people read these threads and bashing a vendor without merit isnt a good way to conduct your self. |
09-27-2009, 01:50 AM
Originally Posted by bandito Willi I see in your 1st post you stated the motor came with a 14 day warranty then you said you rode it for 2 weeks then the problems started happening. Whats the issue with the vendor here? You knew going in there was only a 14 day warranty didnt you? I dont see any efforts stated on your part trying to work with the vendor to correct any problems. My point is that alot of people read these threads and bashing a vendor without merit isnt a good way to conduct your self. | no i DID NOT know about the two week warranty, until after anyways its over now! | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 03:54 PM. | | | Sponsors
