Bicycle Engine KitsMost motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here!
Bushing
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. I was going to take my head off and replace my bushing. Any pointers are apreciated. take bolts off slide ...
I was going to take my head off and replace my bushing. Any pointers are apreciated. take bolts off slide head off. take little retainer clip off of bushing, replace bushing, put clip back in line rings up with nipple, make sure piston pointing in same direction rplace gaskets torque to about 10 lbs criss cross right?
Sounds like you got a handle on it...you can go a little tighter- 25-20 ft/lbs on the studs if they are the 8mm studs.
Where did you get the bushing? Price? Link?
__________________ If it ain't broke, and you mess with it long enough, it will be.
I found a bushing. the bushing does not have a oil hole in it. Anyone have any advice or ideas on how to drill one of these holes. Hope I do not get burrs on the inside.
