Breaking-in a new engine
Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. I've been running brand new engines with sabre at 50:1 even during brak in 4 so far that ...
  #21 (permalink)
Old 11-02-2009, 11:13 PM
flybytaco's Avatar
Default Re: Breaking-in a new engine
I've been running brand new engines with sabre at 50:1 even during brak in 4 so far that show no sighn of quitting
couldnt build my bikes without PIRATE CYCLES and billet from CREATIVE!!!!! THANKS JUSTIN!!
  #22 (permalink)
Old 11-02-2009, 11:32 PM
is there a specific mixture that your suppose to stick to? you say you used 50:1 ive been told 28:1 is there a factory set mixture for these engines?
  #23 (permalink)
Old 11-02-2009, 11:49 PM
Junster's Avatar
This is a very contested subject. I lost one of the ring groove pins that keep the rings from rotating. I did the lots o oil real slow break in the first time. I did get 2500 miles out of it. I tore it apart to fix it and the piston showed tons of blowby. Heavy black streaking down the majority of the outside of the piston. I just rebuilt the top end and this time I used opti-2 at 50:1. I warmed it up for about 5 minutes then rode it hard for about 20 miles. Going from wide open to about half speed then wide open again. the wide open parts for 2-3 minutes at a time. I let it slow to a idle twice during the 20 miles (that suppose to let any metals leave the ring grooves) I do have a shift kit now so my wide open is not over reved. I have about 150 miles on the rebuild now. I removed the exhaust and looked in the port while I rolled the motor over. The piston is very clean, I have great compression, the bike is faster then ever. These cylinders have such a fine cross hone on them you only have about the first 20-25 miles to get the rings broken in. Once the cross hone is worn off there's nothing left to break the rings in against. I vote in favor of breaking it in hard and quick. Let it warm up well at least 5 minutes then go for it. The old breakin methods were for motors with the old cross hones that were heavily grooved and took a while to wear smooth. Just my opinion thou.
Put something FUN between your legs..
  #24 (permalink)
Old 11-03-2009, 05:46 AM
I had similar experiience to Junster and favor "hard and quick" breakin. I learned this from ice racing and motocross buddies and noticed easy breakin was resulting in weaker motors. Only difference is I use 50:1 Walmart oil from the start instead of synthetic.
  #25 (permalink)
Old 11-03-2009, 09:00 AM
Bikeguy Joe's Avatar
I run everything here that is two stroke on 40:1 mix.
The "instructions" can be thrown away as soon as you get them out of the box. They usually state 16:1 or 20:1. That is waaaay too much oil, and detrimental to the engine.
Break them in at 24 or 25:1 and go to 32 to 50:1 after.
  #26 (permalink)
Old 11-03-2009, 09:07 AM
I agree with Joe, anything 32:1 or higher is better. My pet peeve is the 16:1 guys that leave a black trail up and down my driveway. Not to mention Al Gore spinning in his grave. (he IS dead isn't he? )
  #27 (permalink)
Old 11-03-2009, 09:15 AM
Nope, just a little fatter and a little grayer.
  #28 (permalink)
Old 11-03-2009, 11:35 AM
Prasinos's Avatar
how about speeds, arent you supposed to keep it at low speeds at first? If so how can you run it wide open for so long?
  #29 (permalink)
Old 11-03-2009, 11:53 AM
Salty Gator's Avatar
When ya first break the motor in run it at 16:1 and open it up from time to time....vary you speed....high low medium....medium low high...blah blah blah....one gallon of mix usually does the trick....that's what I did...then went to 32:1....then 40:1....am about to try a 50:1 synthetic mix...my bike has almost 1000 miles on it without any signs of wear....runs like a bat out of h*ll....hope this helps...
Laters,
Salty
  #30 (permalink)
Old 11-03-2009, 12:44 PM
Prasinos's Avatar
so don't keep it under 20 or anything like that, just don't run it too hard the whole time.
Am i getting that right?
Also is there any oil would be better for break in than others? I hear good things about opti 2.
