Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Bicycle Engine Kits
Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here!
Brainstorm 2-stroke bogging with me....
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. Interesting. My gas cap leaks a little so I didn't think it was a sealed system....
  #21 (permalink)
Old 03-16-2008, 08:28 PM
Pablo's Avatar
Default Re: Brainstorm 2-stroke bogging with me....
  #22 (permalink)
Old 03-16-2008, 08:35 PM
deacon's Avatar
okay your manifold gasket was screwed up... right
  #23 (permalink)
Old 03-16-2008, 08:38 PM
Pablo's Avatar
It WAS so I thought EUREKA - so I fixed it and it did produce better mid-range power, but still dies a WOT.
  #24 (permalink)
Old 03-16-2008, 08:48 PM
deacon's Avatar
Yes but I fixed mine and it did the same things as before so I cut one from a cereal box and I sealed it on both sides and it stopped. I had removed the manifold to work on the engine and broken the seal when I reinstalled it I didn't use gasket seal so it had a leak somewhere from not being sealed. it might seem that I have had about everything go wrong with mine because I DID
  #25 (permalink)
Old 03-16-2008, 08:57 PM
Pablo's Avatar
The possibility exists that it is leaking....I'll get some gasket material tomorrow.
But also I do want to try the lean groove on the needle first.
If neither of those things work, I'll open the carb back up and check the float needle...
  #26 (permalink)
Old 03-16-2008, 08:59 PM
deacon's Avatar
good luck with it
  #27 (permalink)
Old 03-16-2008, 10:29 PM
Pablo's Avatar
I'm really starting to think it just may be a high RPM spark problem......
  #28 (permalink)
Old 03-17-2008, 08:12 AM
Pablo's Avatar
OR that somehow my needle and jet fit are just defective. It's always done this even though I've rode the bike I never went full throttle without the booooooooggggggggg.....I just stayed away from that region, so to speak.
I will take the carb off again after I try the lean clip position.
I will measure the jet size.......
  #29 (permalink)
Old 04-01-2008, 05:49 PM
Pablo's Avatar
Just so anyone reading this thread knows - I solved this problem with a new $22 same as carb and have yet to determine what was wrong with the old carb.
  #30 (permalink)
Old 04-04-2008, 04:13 PM
Pablo's Avatar
Old carb US Posted to Der Normeister. $4.60 express flight to Pampa Techsass.
Advertisers
