| | | 2 Stroke Bicycle Engines & Kits 2 stroke motorized bicycle engine kits need careful installation and setup, find out how from our professionals here! | bike won't run unless on choke. Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. My bike won't run unless the choke is fully or 3/4 on. It order for it to be ...  |
06-19-2009, 04:17 PM
| | Motorized Bicycle Newbie | | Join Date: Jun 2009 Location: pa
| | bike won't run unless on choke. My bike won't run unless the choke is fully or 3/4 on. It order for it to be able to have some power and pull me over 5mph I need it to be on no choke. On full choke it will idle well. When I switch it to no choke it will idle for 3 seconds then die. This will happen at half choke to. Is it not getting enough gas? |
06-19-2009, 04:31 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2008 Location: Treasure Coast, Florida
| | Re: bike won't run unless on choke. Not enough gas OR too much air. Sounds like it might be an air leak. I would check the connections from the carb to the manifold and the manifold to the cylinder....
06-19-2009, 04:54 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: Oregon
| | Re: bike won't run unless on choke. Check all your gaskets even your exhaust as it can cause the issue like an airleak would also. I had the same issue but it didn't look like my gasket had done anything actually it
had blown out and a peice went down my Muffler ended up blocking my out put. it would run fine on choke or at low speeds but died when I got on it. Also do you use a fuel filter? if not pull out your little brass "fuel in line" it may be clogged and only letting a little gas through. |
06-19-2009, 05:02 PM
|  | Motorized Bicycle Elite Member | | Join Date: Mar 2009 Location: upstate NY
| | Re: bike won't run unless on choke. put a o-ring washer in your carb to intake,that will stop your airleak. |
06-19-2009, 08:50 PM
| | Re: bike won't run unless on choke. If there are NO air leaks... you need a bigger jet. (you can drill it to make it bigger)
It's real easy, I can tell you how.
I've had this problem on a few of my bikes. Every one was fixed by drilling the jet.  |
06-21-2009, 05:20 PM
| | Re: bike won't run unless on choke. Use some kinda spray wd-40, brake cleaner. Small squirts where the carb hooks to the intake, where the intake hooks to the cylinder, around the base of the cylinder. When you hit the leak it will either speed up or slow the idle. The screw on the left side of the carb with the spring on it is the idle, screw it in a couple turns. Also if you only have a few minutes on motor the idle is going to get alot better with an hour or two run time.
__________________ Put something FUN between your legs.. |
06-22-2009, 08:14 PM
| | Motorized Bicycle Member | | Join Date: Mar 2009 Location: middle of nowhere
| | Re: bike won't run unless on choke. let me know if anything works my go-kart occasionly has this prob
i take off the fuel pump
blast it with carb cleaner
put it back on
runs for a few hours to a few days
If the world were a perfect place we could teleport.
Untill then we are under the rule of OILOPLIS
aka oil compyns. if you think this is wrong and want to break our dependince google david blume
or google knowledg publacations
fix the spelling u self |
06-23-2009, 09:18 AM
| | Motorized Bicycle Newbie | | Join Date: May 2009 Location: alabama
| | Re: bike won't run unless on choke. I locked up a motor with the same problem it sounds like an air leak use carb cleaner and spray around the motor until when you spray a spot it tries to go dead |
06-23-2009, 09:27 AM
| | Re: bike won't run unless on choke. Just be careful spraying the brake cleaner or carb cleaner....better to use some thing like water in a misting bottle or wd-40
06-23-2009, 09:37 AM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: Los Osos, California
| | Re: bike won't run unless on choke. I had a similar problem on my newly assembled bike. It turned out that the main jet holder was sitting down in the float, completely unscrewed. Remove the float bowl and check it. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:09 PM. | | | Sponsors
