Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Bicycle Engine Kits
bicycle motor spark plug wire replacement
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. i thought we had this somewhere and couldn't find it. the cdi which your plug wire goes to has ...
Old 03-12-2008, 09:40 PM
CRUISER's Avatar
ADMINISTRATOR
Default bicycle motor spark plug wire replacement
i thought we had this somewhere and couldn't find it. the cdi which your plug wire goes to has a screw in it that you basically screw the wire onto. a picture of the inside of the original cap is below and the cd has the same screw in it for conductivity. if you replace the wire you need 7mm good quality plug wire. to make it easier to screw into the cdi pre screw the end of the wire with a small screw like you would do with a piece of wood or metal making a pilot hole. also if you replace the boot with a good one you need to put the little screw cap on the end of the plug. you will notice a big performance change with a good wire in most cases. for me it made the biggest improvement to date on my motorized bicycle
http://stockmarketcats.com/
Old 03-13-2008, 06:29 AM
Bikeguy Joe's Avatar
Default Re: bicycle motor spark plug wire replacement
Also, if you spray a little silicone on the outside, it will help it go in better and give it slightly better protection against moisture.
Similar Threads
lights using the white wire that really work Norman Swap Shop 31 07-05-2008 09:02 AM
norman's white wire motorized bicycle head light CRUISER Motorized Bicycle General Discussion 5 04-30-2008 12:59 PM
How to wire Chinese 2-Stroke bicycle engine CRUISER Bicycle Engine Kits 4 03-19-2008 10:25 AM
Bicycle Motor Spark Problem? buttburn Motorized Bicycle General Discussion 28 03-13-2008 05:30 PM
Troble shooting bicycle engine cdi and spark plug wire deacon Motorized Bicycle General Discussion 19 01-23-2008 09:58 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
