Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Bicycle Engine Kits
Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here!
bicycle engine clutch.
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. Super easy to turn with the clutch lever pulled in (clutch not engaged)...
  #41 (permalink)
Old 05-03-2008, 07:50 AM
Pablo's Avatar
Default Re: bicycle engine clutch.
  #42 (permalink)
Old 05-03-2008, 10:42 AM
Yes, just use your fingers. Having the clutch lever pulled "IN" takes the pressure off. I went finger tight and backed off about a half turn.
  #43 (permalink)
Old 05-04-2008, 06:53 AM
Bikeguy Joe's Avatar
Yesh, yesh it is.
  #44 (permalink)
Old 05-29-2008, 02:06 PM
fairracing31's Avatar
Clutch check
YouTube - bicycle engine kit clutch checklist
  #45 (permalink)
Old 08-19-2008, 10:07 AM
Motorized Bicycle Apprentice
My clutch arm swings loosely. No pressure against against the push rod.
  #46 (permalink)
Old 08-19-2008, 10:09 AM
Sounds like the rod and/or ball are missing, did you have the cover off? Engine new or used?
  #47 (permalink)
Old 08-19-2008, 02:37 PM
I got it from Dax a little over a month ago and have just now gotten around to it.
I took off the clutch arm cover last night.
  #48 (permalink)
Old 08-19-2008, 03:20 PM
Check to see if there is a rod, and behind that, a ball. They both go in the center of the drive sprocket.
  #49 (permalink)
Old 08-19-2008, 08:52 PM
lennyharp's Avatar
I have had to clean my clutch pads about 5 times after almost every 20 minutes of riding. I tighten the star nut till it will not tighten more and it slips until I clean the pads. The system would not start and still won't as the slippage is so bad until I clean the pads. Will I get past this? Am I doing something wrong? This thread documents my build.. 1970 Schwinn Heavy Duty Oh yes the screw that locks the star nut is scouring a line on the cover that I have enlarged with my Dremel Tool.
LennyHarp of Lenny's Bikes & Things
http://lennyharp.net
  #50 (permalink)
Old 08-19-2008, 09:14 PM
ran49's Avatar
Lennyharp:
When you tighten the star nut I assume you have the clutch handle locked in the disengaged position.Even then the clutch may not be completely disengaged depending on on the cable adjustment.Try pulling back on the clutch lever with one hand while adjusting the star nut.There might be a little more slack in there.Happened to me.Ron
Similar Threads
Moutain bike - clutch/brake lever?? Pablo Mounting Techniques 20 06-29-2008 07:28 PM
Bicycle engine Paint troy994719 Paint Booth & Chop Shop 9 03-07-2008 09:04 PM
bicycle engine CRUISER Motorized Bicycle General Discussion 13 03-07-2008 07:04 PM
motor bicycle clutch Norman Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 7 02-11-2008 07:04 AM
Motorized bicycle engine top end rebuild and an engine stand Norman Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 16 02-11-2008 06:40 AM
