Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Gas Bicycle Engine Kits
Gas Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here!
bicycle engine clutch.
Discussion at Motorized Bicycle Engine Kit Forum in the Gas Bicycle Engine Kits forum. I did get it tighter and hopefully that will resolve my slippage issues. I'll test it tomorrow....
  #51 (permalink)
Old 08-20-2008, 12:13 AM
lennyharp's Avatar
Default Re: bicycle engine clutch.
LennyHarp of Lenny's Bikes & Things
http://lennyharp.net
  #52 (permalink)
Old 08-20-2008, 07:24 AM
Bikeguy Joe's Avatar
MODERATOR
You can try sanding the pucks and pressure plate with some medium sandpaper.
Are you sure your clutch is releasing all the way (tension too tight on cable housing)?
I can't think of anything else.
  #53 (permalink)
Old 09-08-2008, 01:33 PM
jasonh's Avatar
So here's one...
My set screw was also gouging into the cover. I tried tightening the star nut, but then I just couldn't disengage the clutch. For now I have a thick cardboard gasket on there to prevent more scoring, but that's lead me to lose all but 2 of the cover plate screws
So here's a list of things that are funky with my clutch:
set screw grinds on cover plate.
the "plate" that the star nut holds on has some play in it both with the clutch engaged and disengaged. It can wiggle and make noise, and will rattle at higher rpms.
The set screw doesn't really set the star nut. If I "set" on one of the tabs of the nut, it lets the nut slip. If I set between the tabs, the nut has that little bit of room to rotate before hitting the screw.
I'm thinking what I need to do is turn the flower nut in all the way, then screw in the two adjusters on the cable, and reset the little brass thingie on the end of the cable. Then use the screw adjusters and try to get the clutch to be able to engage/disengage. Not sure that'll work, but it's worth a shot.
Any suggestions to keep that plate from rattling? Drives me nuts at higher rpms.
  #54 (permalink)
Old 09-08-2008, 04:10 PM
lennyharp's Avatar
I did the sanding trick and the clean the pads trick and took needle nose pliers to the star nut and worked it in as far as I could while pulling the clutch lever. All that kept the clutch working for a few hundred miles till the motor mount bolt broke off at the block.
The set screw does go between the tabs of the nut and it can only back out so far before it hits the screw.
  #55 (permalink)
Old 09-26-2008, 12:11 PM
Just as an update...
The newer "80cc" motors now have round clutch material pieces. Don't think the round have as much surface area as the older ones.
Had to take apart and tighten the star nut a bunch to stop the slipping / squealing after only 3 tanks of gas.
Advertisers
