Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Gas Bicycle Engine Kits
Gas Bicycle Engine Kits Most motorized bicycle engine kits are either a 2 stroke or 4 stroke. Both need careful installation and setup, find out from our professionals here!
bicycle engine clutch.
Discussion at Motorized Bicycle Engine Kit Forum in the Gas Bicycle Engine Kits forum. Something else take off the lower cable mount and shoot some grease in the hole watch for it to come ...
  #31 (permalink)
Old 03-16-2008, 12:46 PM
Norman's Avatar
LORD VADER Moderator
Default Re: bicycle engine clutch.
Something else take off the lower cable mount and shoot some grease in the hole watch for it to come out around the bearings behind the sprocket and behind the clutch this is where the real spring for the clutch lives and if you look at my total tear down you will see just what is in there.
Hope this will help you out all kinds of good stuff here to do and try. I don't think any other forum has done a complete tear down with pictures and text like is on here hope all this info will get you a good running ride on your motorized bicycle.
Norman
norms-iron-works.tripod.com
Last edited by Norman : 03-16-2008 at 12:48 PM. Reason: needed to add more on bicycle motor stuff
  #32 (permalink)
Old 03-16-2008, 01:51 PM
Bikeguy Joe's Avatar
MODERATOR
Originally Posted by dgoria5 View Post
I can't wait to ride!
G's!!! I can't either. It's been a long winter.
  #33 (permalink)
Old 03-22-2008, 04:36 AM
bgoates's Avatar
My bike motor seems to have a whining sound.....is this normal ? The clutch seems to be correctly adjusted so I'm not sure if it is coming from that or something else. Any ideas ?
Many thanks....
PS..I ordered another kit today to make one for my son. This one should go together much easier.
  #34 (permalink)
Old 03-22-2008, 06:21 AM
MODERATOR
Yes, these engines have some pretty wicked gear whine, some more than others.
Check the gears and make sure they have a small amount of grease on them. Lithium or high pressure wheel bearing grease work best- just a little dab will do ya'.
  #35 (permalink)
Old 03-23-2008, 12:53 PM
Easy Rider's Avatar
Hi Norm, I noticed your clutch pucks look different from the ones we had. Is that an older style motor? Is it a one piece clutch or is it the same concept as the motors we got from DAX?
Thanks,
Ken
  #36 (permalink)
Old 03-23-2008, 07:00 PM
Norman's Avatar
Easy
I'm not sure I have a Dax engine I could pull off the clutch plate and take a look I got one from Kings and the rest from boygofast so beats me!
  #37 (permalink)
Old 03-26-2008, 03:26 AM
Norman says counter clockwise and I would add that it wont take much, I'd try less that one turn.
  #38 (permalink)
Old 03-26-2008, 05:42 AM
deacon's Avatar
When I need to adjust my cable end, I take it out of the arm move it where i think it needs to be tighten it, then push the arm back until I can slide the cable in. Work like a champ for me.
visit my blog for Riding in the hood,... The home brew bike journal....http://frictiondrivebicycles.blogspot.com/ The deacon's fiction
  #39 (permalink)
Old 03-26-2008, 06:41 AM
MODERATOR
What are you turning counter clock-wise, and for what purpose?
  #40 (permalink)
Old 05-03-2008, 08:35 AM
Okay, do not have to take the small gear off to turn the clover nut thing. Okay, let me get this straight. Pull the clutchin and lock it then remove the set screw, then turn clover nut clockwise. Then put set screw back in. The clover nut does not look like it has anything to put a wrench on from the photos, must be easy to turn hu?
Advertisers
