Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Bicycle Engine Kits
Bending bicycle engine exhaust
Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. Anyone know how to bend the exaust so it will fit a frame, or bend it the way you want ...
Old 05-13-2008, 11:40 PM
Default Bending bicycle engine exhaust
Anyone know how to bend the exaust so it will fit a frame, or bend it the way you want it. Heat it up, or will that chip the chrome off.
Old 05-14-2008, 12:00 AM
Can Harm Hen's Avatar
Default Re: Bending exaust
I went to the art department workshop on campus and borrowed their acetylene torch. Did the trick, but it leaves the pipe discolored. Doesn't bother me a bit, as long as it works.
-Herman
"Do not take life too seriously. You will never get out of it alive." -Elbert Hubbard
Old 05-14-2008, 05:50 AM
Bikeguy Joe's Avatar
For the best results, fill the pipe with sand, heat it cherry red in an area about 3-4" long and bend it over a curved object like a big steel pipe or other steel object about the radius of the bend you want.
The sand reduces the possibility of kinking the pipe. You will ruin the chrome.
Some have bent the pipe slightly (less than an inch to clear the pedal crank of front fenders on some bikes) with no heat, if you want to try a moderate bend (under 45 degrees) without heat, still use the other steps above.
Old 05-14-2008, 07:52 AM
CRUISER's Avatar
ADMINISTRATOR
i personally could not bend it at all so opted to bend the crank out a little to clear the exaust which was a hole lot easier
http://stockmarketcats.com/
Old 05-15-2008, 01:44 PM
Default Re: Bending bicycle engine exhaust
I took a sledgehammer to the pipe and it didn't bend. Propane torches don't get hot enough either.
-Herman
Old 05-15-2008, 06:03 PM
Oxy/Acetyline will.
Old 05-15-2008, 10:56 PM
cityevader's Avatar
The crank bent before the exhaust! Holy mackerel!!!
Perhaps my mountain biking background has my perception of cranks trapped, but I can't even fathom bending a crank. Perhaps street bikes or cruisers are not built as stout?
You could take you're pipe to a muffler shop, not only do they have the right torch, but will also have a tubing bending tool. If they have the right die set, you could possibly bend it without heat or cracking off the chrome, depending on the amount of bend of course.
Old 05-17-2008, 05:37 AM
CRUISER's Avatar
ADMINISTRATOR
lol well my pedal bicycle their is no way i would bend the crank however i only pedal my motorized bicycle enough to get it started so was not worried about it and it did the trick
  #9 (permalink)
Old 05-17-2008, 10:34 PM
Protect the exhaust pipe with wood in a vise. Bend it slowly. No heat needed. You may have to stand up and pull on it. But make sure you block it off with wood to not damage the chrome. Bend it slow so the chrome will not peel. Enjoy the ride...
visit www.thatsdax.com for more !!
Similar Threads
70cc bicycle engine vs. 50cc bicycle engine RedB66 Pre-Motorized Bicycle Information. 9 05-27-2008 08:48 AM
Exhaust leaking black oily gook SeattleMike Motorized Bicycle General Discussion 32 05-24-2008 05:07 PM
motor bicycle exhaust biker Bicycle Engine Kits 34 05-14-2008 09:04 PM
How to make your own exhaust pipe Ilikeabikea Motorized Bicycle General Discussion 5 03-15-2008 05:14 PM
Motorized bicycle engine top end rebuild and an engine stand Norman Classic Instructions for Building and Repairing Motorized Bicycle Engine Kits 16 02-11-2008 06:40 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25
