| | | 2 Stroke Bicycle Engines & Kits 2 stroke motorized bicycle engine kits need careful installation and setup, find out how from our professionals here! | 2-stroke magneto Discussion at Motorized Bicycle Engine Kit Forum in the 2 Stroke Bicycle Engines & Kits forum. I was doing a check on my Grubee Skyhawk 66cc engine and
started to unloosen the screws on the outside ...  | |
10-05-2009, 10:48 AM
|  | Motorized Bicycle Elite Member | | Join Date: Dec 2008 Location: west-central Illinois
| | 2-stroke magneto I was doing a check on my Grubee Skyhawk 66cc engine and
started to unloosen the screws on the outside cover of the magneto and noticed oil dripping out the bottom front screw. Is this a sign of trouble to
come? This engine has only 3 1/4 gallons of fuel ran through it. |
10-05-2009, 12:10 PM
| | Re: 2-stroke magneto Sounds like a bad oil seal... I don't know if oil on the mag will cause problems or not? Just don't let the oil get to heavy inside the cover; & run it until it dies!! |
10-05-2009, 02:28 PM
| | Re: 2-stroke magneto I rode the bicycle about 1 1/2 miles before I had to pull
the clutch in to idle at an intersection and the engine quit
running. Tried to restart with no luck. I peddled up a good
size hill and went fast down it and engaged the clutch and
it started and ran until I got home with it and at idle died
again. This engine did not last long at all. It was fun while it
lasted thou. Engine is still under warranty but I did not break
the engine in at 16 to 1 as recommened in the book. |
10-05-2009, 09:18 PM
| | Re: 2-stroke magneto Break 'em in with 24:1!!
16:1 is for mixing regular motor oil, not 2-cycle oil!
The oil in the mag area might ground it out?? |
10-05-2009, 09:20 PM
| | Motorized Bicycle Senior Member | | Join Date: Apr 2009 Location: somewhere around you
| | Re: 2-stroke magneto ya yah thats where i went wrong on mine! later willi |
10-06-2009, 10:27 AM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: ny,ny
| | Re: 2-stroke magneto I break all of mine in with 50:1 Walmart oil.
And note that oil does not conduct electricity. It's what they use for dielectric inside industrial transformers and capacitors. |
10-06-2009, 11:38 AM
| | Re: 2-stroke magneto Quote:
Originally Posted by xlite I break all of mine in with 50:1 Walmart oil.
And note that oil does not conduct electricity. It's what they use for dielectric inside industrial transformers and capacitors. | How about the gas thats mixed with the oil? will that conduct the electricity??  |
10-06-2009, 12:20 PM
Originally Posted by VENICE BOY How about the gas thats mixed with the oil? will that conduct the electricity??  | Nope. Even if it has LEAD in it. And note pure water is a poor conductor also.
As a general rule if it's metal it conducts, if it's not it don't. Generally  . |
10-06-2009, 01:16 PM
| | Re: 2-stroke magneto The real question is, 'could it short out the mag coil?' Maybe? |
10-06-2009, 01:31 PM
Originally Posted by VENICE BOY The real question is, 'could it short out the mag coil?' Maybe? | Not short but I think gas might dissolve enamel on the super thin magnet wire. Water might cause electrolytic corrosion. Although my magnetos have been exposed to both without harmful effects (knock on wood). Using that white wire seems the only common factor in my case. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:39 PM. | | | Sponsors
