are 2 stroke engine kits the same? absolutely not! i have been researching this to try to find the answer. their is numerous company's producing the motors in china. they may look the same but they are not. what made me look into this is my first motor was the cheapest i could find and it had bushing bearings and wanted to replace them with roller bearings but they would not fit. the similarities in the motors is basics like carburetors and exhaust mounts are the same. however their is like 4 different styles and lengths of exhaust available of different kits i have found. same with cdi's. they may look the same but they are different depending on who manufactures them. some have less winding and less windings mean less power. the ohms on the cdi's can range from 257 ohms to 353 ohms of course the 353 ohm cdi is the better of them. same with carburetors. their is 2 different size slides and one will not work on the other. the bigger one is 1.5 mm larger. spark plug wires i know this from my kit. it was a piece of junk and it was like having a new motor when i replaced it. the engine itself some use 6mm cylinder studs, others use 8mm, Counter shaft sprockets are different. Some have larger cooling fins, and more. Here is what items I have found that are similar and can work with most of the other engines. Side covers, Magnetos, CDI's, Spark Plugs, Carbs. kinda like some car parts are interchangeable or AA batteries all look the same but they sure the heck are not. however things like pistons, rings, bushings ect are not interchangebable. so to wrap this up they may look the same from the outside but inside these engines are different and each manufacture in china has thier own inhouse inspections. take your time when you buy an engine and make sure it has a good cdi, wires, bearings ect. hope this helps clear things up a little |
