| | 2 stroke bicycle engine - getting richer with break-in?? Discussion at Motorized Bicycle Engine Kit Forum in the Bicycle Engine Kits forum. Just as the title says, did your 70cc 2 stroke engine - get richer with break-in??
I'm just about ...  | |
03-10-2008, 12:54 PM
|  | Amsoil Dealer | | Join Date: Dec 2007 Location: Duvall, WA PNW
| | 2 stroke bicycle engine - getting richer with break-in?? Just as the title says, did your 70cc 2 stroke engine - get richer with break-in??
I'm just about done with my first tank of fuel (as a time measure) and the engine is still somewhat breaking in. The only problem now is that it's getting progressively richer - to the point of me wanting to go messing with the needle. Plug is wet with fuel and when warm if I wick on full throttle it really bogs and sops with unburned fuel. |
03-10-2008, 01:27 PM
| | Re: 2 stroke engine - getting richer with break-in?? Then move the needle. There doesn't seem to be any rules. If it isn't doing right try it you can always move it back. |
03-10-2008, 01:29 PM
|  | Motorized Bicycle Builder | | Join Date: Mar 2008 Location: Davis, California
| | Re: 2 stroke engine - getting richer with break-in?? Have you tried changing the spark plug and wire? My spark plug wire actually fell apart after the second tank of gas. Thanks to cruiser, who sent me a new one!
-Herman "Do not take life too seriously. You will never get out of it alive." -Elbert Hubbard
03-10-2008, 04:37 PM
| | Re: 2 stroke bicycle engine - getting richer with break-in?? I'll say the plug is definitely a real piece....try a new NGK first, then if it's still rich, change the needle.
It is possible that it can "get richer" since, after the engine starts to break in, will make more compression and draw a better charge into the cylinder each stroke.
Also, check your air cleaner element, mine got full of crud and spit back fuel relatively quick.
03-10-2008, 04:38 PM
| | Re: 2 stroke bicycle engine - getting richer with break-in?? BTW- break in is usually done after a few hundred miles. (two or three tanks at least)
03-10-2008, 07:28 PM
| | Re: 2 stroke bicycle engine - getting richer with break-in?? Plug (NGK B5HS) (and wire (ala cruiser)) are fine.....but does get fuel wet when it bogs.
I know the engine isn't fully broken in.......I may try the leaner notch. |
03-10-2008, 07:30 PM
| | Re: 2 stroke bicycle engine - getting richer with break-in?? might not help but it can't hoit |
03-11-2008, 04:24 PM
| | Re: 2 stroke bicycle engine - getting richer with break-in?? Didya check the air filter element?
03-11-2008, 04:28 PM
| | Re: 2 stroke bicycle engine - getting richer with break-in?? Happens with no filter. I will however check my carb....something may be goofy with it, I think it's leaking more fuel than normal.... |
03-11-2008, 04:38 PM
| | Re: 2 stroke bicycle engine - getting richer with break-in?? Float sticking?
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:38 PM. |
