Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycke engine? Just ask Norm. he loves to tinker and troubleshoot engines.
will this work
Discussion at Motorized Bicycle Engine Kit Forum in the Norm's 2 stroke repair center forum. My float filled with fuel so I got some cork The same diamiter and thickness then drilled .350 thru center. ...
Old 08-10-2009, 07:33 PM
Default will this work
My float filled with fuel so I got some cork The same diamiter and thickness then drilled .350 thru center. Does anyone think it will clog the carburator ? Thanks
will-work-picture-2.jpg  will-work-picture-3.jpg  will-work-picture-4.jpg  will-work-picture-5.jpg
Old 08-10-2009, 08:35 PM
mechanickid's Avatar
Default Re: will this work
yea the gas will soften that up a TON and it will fall apart, but for about an hour its good in an emergency
its only too fast if you cant stay on!
Old 08-10-2009, 09:05 PM
What if I coat it with Seal- All (gas and oil resistant ) ?
Old 08-10-2009, 09:14 PM
I didnt know gas softened up cork...? Does it?
Many old school gaskets were made out of that material in many different ol engines.
"Burn after reading"
Old 08-11-2009, 10:53 AM
fairracing31's Avatar
Some one like a year ago tried to use cork for a float but it just fell apart after a little while.
Old 08-11-2009, 11:24 AM
Ilikeabikea's Avatar
Lots of old airplanes used cork floats for fuel guages. They put some kind of sealer on them but they would last a long time........
http://www.galtx.org/
http://bdconner.com
Old 08-11-2009, 12:30 PM
I'm gonna coat it with seal- all and try it. I'll let everyone know how it turned out and how long it lasts. Thanks
Old 08-11-2009, 01:56 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
You're probably better off using a real stock float!!! You don't know if that one will keep the same fuel level in the float bowl that a stock one will!!!
  #9 (permalink)
Old 08-11-2009, 07:06 PM
if you coat it with something that gas (and ethanol in the gas..) won't eat it should work fine. You'll definitely need to re-adjust the float level because it will float differently, you may need to adjust the jet and the needle to make it work. But if you are like me you are cheap and would rather play with the carb to make it work right than buy the correct part
  #10 (permalink)
Old 08-11-2009, 08:06 PM
Rather than spend $1, & do it the right way (& easier way)... Some people always need to spend $5 & prove to themselves they do it the hard way...
Just be careful not to run your engine too lean!!
