Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycke engine? Just ask Norm. he loves to tinker and troubleshoot engines.
synthetic oil?
Discussion at Motorized Bicycle Engine Kit Forum in the Norm's 2 stroke repair center forum. Can't find anything by searching. I'm wondering what's the consensus here on using synthetic oil? I bought ...
Old 06-06-2009, 09:50 AM
Default synthetic oil?
Can't find anything by searching. I'm wondering what's the consensus here on using synthetic oil? I bought some but haven't tried it yet. What I'm wondering is that the bottle seems to be indicating that it doesn't matter what the oi/gas ratio is, just add the whole 2.6 oz. bottle to one gallon of gas. Does this make sense?
Old 06-06-2009, 10:07 AM
Pablo's Avatar
Default Re: synthetic oil?
That's 50:1. What oil are you talking about?
Synthetic oil is a good thing, but IMHO most HT engine deaths are related to design and khrap assembly, not oil basestock choice.
Old 06-06-2009, 12:17 PM
The label reads:
pro-mix Premium
2 cycle engine oil
Designed for use with 50:1 40:1 32:1 & 16:1 Mix ratios
Low smoke - fuel stabilizer - synthetic blend
2.6 fl. oz. (77ml)
Add entire bottle to 1 gallon of gas.
Yes, that would be only about half of what I've been using with regular 2 cycle oil. I've heard that you can use less oil with synthetic, but how much less?
Old 06-06-2009, 05:16 PM
Wink Re: synthetic oil?
I run 50:1 Amsoil Saber synthetic. About 400miles so far so good.
Old 06-06-2009, 11:15 PM
i use sinthetic oil i bought my at home depot the bottle is call rioni and i am using 20:1 for the first two gallons of gas which is about6.4 ounces and after that i am going to use32:1 which is about 4 ounces of oil sinthetic oil is good for your engine
Old 06-07-2009, 08:57 AM
The engine I'm running right now has around 500 miles on it so it's completely broken in. I'm going to go with the 2.6 oz. to one gallon or 50:1, and see what happens. I suppose how you drive is a factor. I don't push the bike hard. I never run it with the throttle wide open.
Hope I don't blow it, but then, I say that every time I go for a ride.
Old 06-07-2009, 09:59 AM
i use amisol sabre...80 to 1...it says 100 to 1.....per pablo...sorry about name dropping...i've tried tried this oil at 50 to 1 and you cannt start the engine...it is dense...great oil...all 3 bikes, everything is ok...XXXXXXDennis
Old 06-07-2009, 11:27 PM
I went to the other extreme and use Walmart 2-stroke outboard oil. It's about $11 a gallon and I mix it about 32:1. The oil is not to be used in high hp/cc outboard engines e.g. Rotax but I'm convinced it's going to be fine for these crude Chinese engines that in China probably get cheap gas mixed with a little old cooking oil. So far, the engine has about 12 hours on it, so about 200-250 miles. Just did a 1 hour ride today and nothing vibrated loose, which is a first.
  #9 (permalink)
Old 06-08-2009, 12:15 AM
doesnt outboard oil have mineral oil as a base?...if it works dont fix it...ha...also i buy the Z-Max kit for my old truck...and in it, it has asmall bottle of Z-Max for 2 stroke engines..i have added 1 oz one time per gallon of gas...it has leankite in it...which is used in jet fuel...it sure tightened things up...ha...great product....the most it would cost is a hundred dollars for a new engine...ha.ha...well i wish you luck, stay in touch and lets see who goes down first...Dennis...
  #10 (permalink)
Old 06-08-2009, 10:20 PM
outboard oil is designed diffrently than normal 2 stroke oil and will ruin your engine..
