Small locating pin came off piston-- 50cc HT engine --The small locating pin came off the top of my piston-floated around inside and scored up the piston bad cut the top ring in half -scored up the cylinder wall--i put a new piston in and jug(piston body) -was going to buy a new engine--none available in Vancouver--engine now starts but runs on the level or downhill--whenever you load up the engine to go uphill it bogs out--is it possible the pin could have done damage to affect compression--have tried all the carb settings i can to no effect--found the pin imbedded in cylinder wall and used a chisel to take it off--it fit!!
will get my friend to check compression tomorrow. |
