Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycke engine? Just ask Norm. he loves to tinker and troubleshoot engines.
noob help
Discussion at Motorized Bicycle Engine Kit Forum in the Norm's 2 stroke repair center forum. If some can give me a DETAIL instructions on hooking the throttle and the clutch it would be awesome...the ...
Old 08-25-2009, 08:50 PM
Default noob help
If some can give me a DETAIL instructions on hooking the throttle and the clutch it would be awesome...the instructions shud be noobish cause i don't know anything about mechanics ive tried hooking both up but my throttle does not retract and my clutch just tighten my clutch bar i have some picture how my clutch is hooked up i know i have the throttle and jet needle on the right thing i just don't get how it will go back to idle. i have not tryed to started the engine yet.
Please help. I need exact instructions to help me and get my dream running
Old 08-25-2009, 11:25 PM
Norman's Avatar
LORD VADER Moderator
Default Re: noob help
this might help you read and look at the photos
motor bicycle clutch
Motorized Bicycle Carburetor install and rebuild
hope this willhelp you out if not let me know.
norman
norms-iron-works.tripod.com
Old 08-25-2009, 11:46 PM
Thats whole clutch this i don't see what the gears have to do with pulling the lever back.
And for the throttle i have everything right im just not getting retraction when all hooked up it only snaps back like barley and stops.
Grrr...
Old 08-26-2009, 04:24 AM
Hey dude, something I did when I first hooked up my clutch cable was not run the cable through the guide that is on top of the engine. Its behind the cyclinder and looks like a bolt that goes into the engine with another bolt with a hole in it running perpendicularly through it. The cable must pass through that bolt first and then through the clutch arm. Get someone to pull the clutch arm in a bit while you tighten up the little brass thing that stops the cable from pulling back also. Not sure if that is the problem you are experiencing but I know its a problem I had due to my noobness and the set of very poor instructions that came with my kit.
Did your throttle come already attached to the carb? If not make sure when you fitted the cable that the washer that sits on the little clip on the needle inside the carb hasnt flipped up right causing it to jam. Also make sure the groove on the barrel/slide/cylinder inside the carb is lined up with the little brass knob inside the carb.
Hope this helps
Old 08-26-2009, 08:10 AM
Bikeguy Joe's Avatar
Turn the throttle slide around.
Post a photo of how your clutch is hooked up, and an explanation of what not working.
Old 08-27-2009, 03:44 AM
Grrr...
Did you line up the groove of the slide with the little pin ??
