| | | Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycke engine? Just ask Norm. he loves to tinker and troubleshoot engines. | Motor stops at comlete stop Discussion at Motorized Bicycle Engine Kit Forum in the Norm's 2 stroke repair center forum. What the title says , my motor stops at a complete stops witch isn't very good if you you are ...  |
10-10-2009, 07:04 PM
| | Motorized Bicycle Member | | Join Date: Jul 2009 Location: Iowa
| | Motor stops at comlete stop What the title says , my motor stops at a complete stops witch isn't very good if you you are crossing a busy intersection.
Thanks. |
10-10-2009, 07:27 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: Mi
| | Re: Motor stops at comlete stop Is your idle too low? |
10-10-2009, 07:41 PM
|  | Motorized Bicycle Elite Member | | Join Date: Nov 2008 Location: Penticton British Columbia Canada
| | Re: Motor stops at comlete stop you can turn up the idle screw and the accelerator adjustment--i had mine purposely set to shut off on my happy times engine but on my morini its not because you have to kick start it with your hand. |
10-10-2009, 08:06 PM
| | Re: Motor stops at comlete stop Well the screw is very tight. The gold one on the carb with a spring. Witch if i'm not correct is the idle screw. |
10-10-2009, 08:31 PM
|  | Motorized Bicycle Senior Member | | Join Date: Jul 2009 Location: chicago
| | Re: Motor stops at comlete stop  Quote:
Originally Posted by Dylanpieper Well the screw is very tight. The gold one on the carb with a spring. Witch if i'm not correct is the idle screw. | Yes that's it, now try to keep it running with the throttle push in the clutch engage the pin so the clutch stays disengaged then turn the screw with the spring untill it runs by it's self. if that does not work maybe it your gas oil mix.
10-11-2009, 12:49 AM
| | Motorized Bicycle Elite Member | | Join Date: Nov 2008 Location: Colorado
| | Re: Motor stops at comlete stop There's a lever that you pull in just before you stop. I remember reading about it once. |
10-11-2009, 08:41 AM
| | Re: Motor stops at comlete stop That was funny.
Does your clutch drag?
10-11-2009, 02:17 PM
| | Re: Motor stops at comlete stop ur suppose to clutch at stop? This is my first bike Ive ever ridden so...Sorry im 13 :P
Clutch Drag? |
10-11-2009, 05:58 PM
| | Re: Motor stops at comlete stop Never mind. Pull the clutch lever in at every stop Dylan.
10-11-2009, 11:00 PM
| | Re: Motor stops at comlete stop | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 05:08 AM. | | | Sponsors
