Re: Little chain snab Dylan,
The chain wil not go on the way you're trying in the video. You must feed it around the sprocket with the clutch disengaged, handlebar lever squeezed. There is not enough clearance at the point you indicated. A trick is to use a socket on the sprocket nut to rotate it or you can pry it around with a screwdriver but be careful doing it that way; you can crack the aluminum case where you pry against it. Also the master link goes on one way. The little spring clip needs to be installed so the closed end goes into the engine first when the rear wheel is rotated forward. Get back to us if you still need help.
Over Youth and Skill |
