Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycke engine? Just ask Norm. he loves to tinker and troubleshoot engines.
installing carburetor on manifold of your motorized bicycle engine
Discussion at Motorized Bicycle Engine Kit Forum in the Norm's 2 stroke repair center forum. Easy way to make a leak free carb to intake manifold. Light coat of silicone rtv on intake manifold but ...
Closed Thread
Old 01-16-2008, 07:56 PM
Norman's Avatar
LORD VADER Moderator
Default installing carburetor on manifold of your motorized bicycle engine
Light coat of silicone rtv on intake manifold but do not get the stuff on the very end of the manifold you don't want it in the carb.
Take your carb and push it on the intake manifold and just as you get it almost all the way on twist it a little and try to line up the casting seam on the carb with the casting seam on the manifold. While holding it in place tighten up the carb mounting bolt. You can ride it now or wait a day. To check for a good seal while engine is running spray the seal area with carb cleaner or starting fluid a change in rpm will mean you need to do it again which I have not had to do again as it worked every time so far.
Norman
Closed Thread
