Re: do you strip the center wire? Marc,
My question would be are you using a metallic core wire? I do and I strip and solder it to the terminal inside the spark plug boot. I use an automotive style boot, not the kit supplied plastic one. If you use a resistance wire such as you'll get from an auto parts store the center core is a carbon or graphite impregnated thread that needs to make good contact with the terminal. You can't solder resistance wire but it does require a good electrical contact to allow your plug to fire properly. Striping and bending it carefully back over the terminal is the best option. Hope this answers your question.
Over Youth and Skill |
