| | | Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycke engine? Just ask Norm. he loves to tinker and troubleshoot engines. | Carb spitting oil Discussion at Motorized Bicycle Engine Kit Forum in the Norm's 2 stroke repair center forum. Hey, I just put my MB together and got it running, I am running a 20:1 for the break ...  | |
08-30-2009, 01:07 PM
| | Motorized Bicycle Member | | Join Date: Aug 2009 Location: atlanta, ga
| | Carb spitting oil**Fixed** Hey, I just put my MB together and got it running, I am running a 20:1 for the break in, The bike starts and idles fine but it will not rev and there is a white foamy oil spitting out of the carb when I hold the throttle open trying to rev it up, I put the clip on the upper slot on the carb to try and lean it out but it does the same thing with no differance at all, I also took the carb apart to see if eveything looked good and I see no problems, no sticking float or loose jet. The exhaust seems clean with no oil dripping out with minimal blue smoke, I'm not sure what to do and any help would be great, Thanks.
Nick
****FIXED IT****
Reason: problem solved
08-30-2009, 01:13 PM
|  | Motorized Bicycle Elite Member | | Join Date: Aug 2009 Location: So Cal
| | Re: Carb spitting oil Have you checked the float height?
It could be set too high, letting too much gas into the float bowl. |
08-30-2009, 01:30 PM
| | Re: Carb spitting oil Yeah, I tried, I bent the little tabs down some and there was no differance at all, thanks |
08-30-2009, 01:40 PM
| | Re: Carb spitting oil Your carb has rabies??? |
08-30-2009, 01:42 PM
| | Re: Carb spitting oil It sure seems that way |
08-30-2009, 01:52 PM
| | Re: Carb spitting oil The only other thing I can think of is that the port timing is off between the intake manifold and crankcase (controlled by the piston moving up and down).
In your case, it being a new engine, this seems to be be a factory flaw.
The intake port is letting part of the intake charge flow backwards out the carburetor instead of only going in like it is supposed to. This is quite possible with a 2 stroke engine and one of the reasons why the reed valve assembly came to be. |
08-30-2009, 02:17 PM
| | Re: Carb spitting oil Have you tried moving the clip down a couple notches to see what happens?
08-30-2009, 05:41 PM
| | Re: Carb spitting oil Well its running good now, THE DARN KILL SWITCH, never would of thought that it could cause something like this to happen but when I disconnect it the bike runs great, hook it back up and it won't rev and starts loading up. My guess there must be some kind of resistance in the switch that is causing the engine to misfire, I know it was hooked up the right way, I had the yellow tapped into the blue wire going to the coil and the black wire was grounded to the frame. I just don't get it. |
08-30-2009, 06:52 PM
| | Motorized Bicycle Newbie | | Join Date: Jan 2009 Location: Beaverton OR
| | Re: Carb spitting oil I just replaced the throttle Housing with Integral Kill Switch from Dax for about twelve bucks and it completely changed the way my engine ran. (I think the kill switch was shorting) Its amazing how something small like that can make a huge diffence. |
08-30-2009, 09:49 PM
| | Re: Carb spitting oil Wow! How on earth could a faulty kill switch cause a carburetor to spit oil?
Very wierd...... | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:03 PM. | | | Sponsors
