Hello Norm,
I am having some issues that I hope that you can hopefully help me out with.
I have full writeup of my problem here:
new member - first install - questions? of course
Basically I am having an issue with either the rear side of the clutch dragging or the cross shaft dragging. In order to determine which is my problem I am proposing that I totally remove the large gear/clutch assembly as you show here:
bicycle engine total tear down
If I remove the large gear/clutch assembly can you verify that the cross shaft should spin freely? answer: with just the clutch arm pulled in the cross shaft should spin freely as long as your clutch is adjusted properly.
If this is true, I need the following questions answered:
1. Is the bolt that holds the large gear on standard or left hand threaded.
answer: it is a right hand thread. If you want to remove any of the gears or sprocket nuts jam a rag between the large gear and small gear to lock up the engine and then you can remove the nuts on the sprocket or large gear the screw slot on the small gear can be a booger to get loose if you do not have a impact hammer tool.Norman
2. Where can I get the puller that is require dto remove the gear, do you have a part #?
answer: If your engine kit didn't come with the puller you can order them from one of the vendors on this forum.Norman
Thanks!!
-Justin
