Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > Norm's 2 stroke repair center
Norm's 2 stroke repair center Having problems with you 2 stroke motorized bicycke engine? Just ask Norm. he loves to tinker and troubleshoot engines.
building a motorized bicycle cable end
Discussion at Motorized Bicycle Engine Kit Forum in the Norm's 2 stroke repair center forum. I'm making a simple cable end that anyone of you can make and carry on your bike for emergency ...
Closed Thread
Old 02-10-2008, 04:15 PM
Norman's Avatar
LORD VADER Moderator
Default building a motorized bicycle cable end
I'm making a simple cable end that anyone of you can make and carry on your bike for emergency road side repairs but you will have to carry tools just for this thing more stuff to loose, Alot of times the cable that breaks will be useless even if you have the end but I thought I'd show you how to and get you all to thinking. If you don't carry an extra cable, just carry the end or for what ever reason. You can skip the threading and drilling for the pinch bolt and silver solder the end on if you want. I don't recommend using regular solder as it will not hold as well if at all. I used a normal 1/4" steel bolt, you can do it that way or use brass for the body. I used a small 6-32" Allen set screw as you can get more torque on it a machine screw might work but then again if you slip tightening it you might stab your hand with the screw driver. Anyway here we go.
norms-iron-works.tripod.com
Old 02-10-2008, 04:17 PM
Norman's Avatar
Default Re: Down and Dirty cable end
self explanatory
building-motorized-bicycle-cable-end-norm001.jpg  building-motorized-bicycle-cable-end-norm002.jpg  building-motorized-bicycle-cable-end-norm003.jpg
Old 02-10-2008, 04:22 PM
Norman's Avatar
1. Drill the hole take your time do not force the bit. Use a center punch to get the drill to start and lube the bit and don't go like a bat out of **** on the drill these little bits will get mad, hot, and break. Got on your safety glasses?
2. I'm deburring the hole do both sides, it won't take much and will save a little on cussing when trying to stick the cable through the hole
3. Cut off the head now. I'm cheating by using the dremel cut off wheel as you can cut the bolt with a hacksaw. I'm lazy and like my new toy.
building-motorized-bicycle-cable-end-norm004.jpg  building-motorized-bicycle-cable-end-norm005.jpg  building-motorized-bicycle-cable-end-norm006.jpg
Old 02-10-2008, 04:35 PM
Norman's Avatar
1. center punch for the hole that will be tapped for the set screw. #36 drill bit and a 6-32 tap for threads. Get it as close to center as you can. This is where a lathe makes it a cake walk but you can do it with out one.
2. the allen head set screw, a thread pitch guage to find out what threads I have and a #36 drill
3. I'm showing about how far I drilled into the bolt go easy on this as well. Just as you beak through the other hole is when the bit will try to bind and break go slow and easy clean the chips often and use oil to lube the drill bit. Fun!
building-motorized-bicycle-cable-end-norm007.jpg  building-motorized-bicycle-cable-end-norm008.jpg  building-motorized-bicycle-cable-end-norm009.jpg
Old 02-10-2008, 04:45 PM
Norman's Avatar
1. Tapping the hole again go slow and easy with a lot of oil to lube and keep the tap from binding. If it breaks here time to start over. All of this can be skipped by silver soldering the little booger on a cable.
2. Now is the time to cut off the excess bolt. man I love my dremel tool. I'm really liking the cordless part of this tool I was afraid it would not have the torque of a cord powered but it works great.( dremel should be sending me a check for the advertisement for them)
3. Chasing the threads just to make sure
building-motorized-bicycle-cable-end-norm010.jpg  building-motorized-bicycle-cable-end-norm011.jpg  building-motorized-bicycle-cable-end-norm012.jpg
Old 02-10-2008, 04:56 PM
Norman's Avatar
1. There it is tighten up on the cable if I was really using this it would be as close to the cables end as possible. wasn't hard was it.
2. a quickie drawing in case the other forums wants to borrow a picture of how to.
3. More than one way to hang a bike. Got the hanger kit at harbor freight for $6.00 on sale normal price is $15.00. I hope it doesn't come loose cause I would be very very angry.
4. 3 of my toys I took the big one out for a 50 mile ride yesterday The old lady and I had a nice ride temps in the 60s.
Thats it for the cable end let me know if it works for you.
building-motorized-bicycle-cable-end-norm013.jpg  building-motorized-bicycle-cable-end-norm014.jpg  building-motorized-bicycle-cable-end-norm015.jpg  building-motorized-bicycle-cable-end-norm016.jpg
Old 02-11-2008, 07:20 AM
Administrator (aka CaribbeanCruiser)
Default Re: building a motorized bicycle cable end
to read all the coments and questions on this thread click here Down and Dirty cable end
Closed Thread
