| | | Board Trackers and Vintage Motorized Bicycles Vintage enthusiast share your board trackers and other vintage motorized bicycle ideas and builds and replicas here | Schwinn Vintage Board Tracker Discussion at Motorized Bicycle Engine Kit Forum in the Board Trackers and Vintage Motorized Bicycles forum. Thanks for the comments, guys. Silverbear, I do plan to run a front brake and was thinking about the Strumey ...  | |
11-06-2009, 12:15 AM
| | Motorized Bicycle Member | | Join Date: Jun 2009 Location: california
| | Re: Schwinn Vintage Board Tracker Thanks for the comments, guys. Silverbear, I do plan to run a front brake and was thinking about the Strumey Archer drum brake. My plan is to unlace the front wheel and reuse the heavy duty spokes that came with the Husky wheel. A local shop can shorten and rethread the spokes for me. I know people will tell me I shouldn't reuse spokes but I am trying to keep this a low buck build and really can't see having problems with reusing 12 gauge spokes. I like the drum brake because that was the style back then and they are more then adequate. A good caliper type brake would work also, but my rims are black annodize and I don't want to burn the finish. They may also look out of place on an old style build like this. |
11-06-2009, 12:36 AM
| | Re: Schwinn Vintage Board Tracker So the build continues. Once the tank was mounted and I had a decent set of wheels and at least a rear brake, I tightened up the bicycle side chain and was ready for some non motorized shake down runs. I had never ridden a board track style bicycle and did not what to expect. A few issues were readily apparent. I had bought a rear fender from Husky Industrial Bikes for $8, shortened it and rolled it forward to put the rear kicked up lip at the top of the wheel. It looked cool but rattled like crazy every time I hit a bump. I added struts to the fender and that soved that problem, solid as a rock. The gearing way way too stiff so that would need changing. The spring on the 60 year old springer fork was too soft and the seat way too hard. I was able to find a heavy duty spring off a Whizzer that really improved the handling of the bike and raised the front end as my weight on the old spring caused the front to settle when I sat on the bike. Just a simple spring made all the difference in the world. As for the seat I wanted something cool like a Brooks Saddle, but they are pretty pricey. Anyway, now I had a fairly solid rider and felt ready to start tackling the motor. Here are a couple shots after the first shake down under human power. |
11-06-2009, 12:59 AM
| | Re: Schwinn Vintage Board Tracker The little 80cc "powerhouse". I have been reading the forum and finding out what people are having problems with and how they are correcting them. It has been a huge help and I appreicate everybody who posts these issues and solutions. I set up the throttle properly, lubed the cable and made sure the throttle snapped close on release. I carefully adjusted the clutch cable. Checked and rechecked all the fasteners using locktite everywhere. I bought an NGK B5HS plug and made a better quality copper core plug wire. I also made a nice muffler support and tied it to the front motor mount so the motor and muffler could torque together instead of tying the muffler to the frame. Oh, and while I was at it I painted the gas tank satin black. I almost left the tank with the brushed stainless finish, but found some really cool Schwinn Motor Bike water slide decals and felt they would look better on black instead of silver. It was getting real close to being a runner, but I still needed a motor side drive system. I had read all the horror stories about cheap chains, sprockets, idlers, and the resulting vibrations that just ruin the whole motor biking experience. That would take some time to figure out. While I was at it I built a nice support stand like I have seen on some of the early board track racers from the 1920's. Here is a shot with the painted tank and almost all systems go. |
11-06-2009, 01:18 AM
|  | Motorized Bicycle Member | | Join Date: Oct 2009 Location: Vista CA
| | Re: Schwinn Vintage Board Tracker Very Very cool bike! Damn it now I need to go down to my shop and work on mine until 2 a.m. Great job man.
__________________ Never think of what you can’t do. |
11-06-2009, 01:22 AM
| | Re: Schwinn Vintage Board Tracker there's absolutely no problems with re-using spokes, as long as they're not bent or kinked up.
here's a link that'll explain it all: Reusing Spokes by Jobst Brandt |
11-06-2009, 11:28 AM
| | Re: Schwinn Vintage Board Tracker Bairdco,
Thanks for that info. I just read it. From what I gather then I just need to keep the spokes in the same relative location to the hub, that is reuse the inside spokes on the inside of the new hub and the outers to the outside of the hub so I don't rebend the spoke head in the opposite direction. That shouldn't be too difficult. |
11-13-2009, 03:22 AM
|  | Motorized Bicycle Member | | Join Date: Jul 2008 Location: MEDFORD, OREGON !!!
| | Re: Schwinn Vintage Board Tracker Quote:
Originally Posted by sportscarpat I almost left the tank with the brushed stainless finish, but found some really cool Schwinn Motor Bike water slide decals and felt they would look better on black instead of silver. | Where did you get the decals? I want some for my bike! They are totally bad ass ! NICE WORK !
GERRY D. FLAT BLACK KUSTOMS. |
11-13-2009, 08:57 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: northeastern Minnesota
| | Re: Schwinn Vintage Board Tracker I love your motorbike. When I can find it on a cd I'll post a photo of a Schwinn motorbike with a slight variation on the decals. Instead of the Schwinn logo it has a spoked wheel that the wing comes off of. I like the whole bike, but it is the tank which really makes it. While I like some of the stretched board track racers and some are just amazing builds, your bike looks very inviting to own and ride. If you ever decide to make and sell those tanks, please let me know and I'll start saving my pennies. You must feel a lot of pride in what you've accomplished. And you should. Well done!
SB
Someday when I grow up I will probably lose interest in toys with wheels, but until then...
11-13-2009, 10:29 AM
| | Motorized Bicycle Elite Member | | Join Date: Jun 2009 Location: KC
| | Re: Schwinn Vintage Board Tracker Nice work! |
11-13-2009, 11:15 AM
| | Re: Schwinn Vintage Board Tracker Thanks for the kind words and nice to finally get some responses on my build thread. Flatbackkustoms, Medford Oregon is a cool place. I used to live up in Coos Bay. I found the stickers on ebay awhile back and just had to have them. They were a perfect fit as they were originally designed to fit on a vintage Schwinn tank bike and I built my tank around that original shape. Silverbear, you had mentioned that you had a straightbar frame also, so this tank design would be a bolt-in on your frame. I have built three tanks now and am currently working on a more shapely design. I have another Panther frame that I may build up as a military bike and have some really cool P40 Warhawk decals for the tank. I have also been working on the motor bike stand. This gives me a solid foundation to support the bike while I am working on it and true to that old board track style I can start the bike and warm it up in the stand. Tank fabrication takes quite a bit of time and if I charged for my time no one would buy them. Each tank does get easier so if your really interested you send me a private email to discuss. Oh, check out the other vintage build by Itchybird, he did an amazing job and his bike also uses one of my fabricated tanks. He disigned that tank and I just did the fab work. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 06:25 AM. | | | Sponsors
