| | | Board Trackers and Vintage Motorized Bicycles Vintage enthusiast share your board trackers and other vintage motorized bicycle ideas and builds and replicas here | Frame materials Discussion at Motorized Bicycle Engine Kit Forum in the Board Trackers and Vintage Motorized Bicycles forum. After looking and looking at exsisting bicycle frame designs new and old, I've come to the conclusion that there ...  | |
09-03-2009, 12:23 AM
|  | Motorized Bicycle Member | | Join Date: Jul 2009 Location: United States
| | Frame materials After looking and looking at exsisting bicycle frame designs new and old, I've come to the conclusion that there must not be an available frame out there that looks convincingly like an old board tracker. If you mix in enough visual cues, you can get close....perhaps at casual glance passable, but not really.
I'm considering building a frame from scratch and I wondering if anyone here has any hands on experience with EMT (electrical metal tubing) i.e. conduit.
It seems fairly heavy gauge, relatively easy to bend, inexpensive and readily availible. I know it's not very good on a strength to weight ratio compared to CroMo and well design aluminum, but without the proper tools to bend, shape and weld those kind of materials, EMT might be a good alternative for home builders.
Here's a couple of links I turned up.... Frame Building - Atomic Zombie™ Extreme Machines Builder's Forum Don Boose builds an EconBent
The second link is for a recumbent bike that actually uses exhaust tubing for the main backbone.
MHF |
09-03-2009, 12:33 AM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: Mi
| | Re: Frame materials Problem with EMT is it is relatively easy to bend. Main reason it doesn't weld "worth poop" is that it's zinc plated and it's usually has a plastic inner coating to make it easier to pull wire though.
Check out your local yellow pages for steel suppliers or welding shops and stop by to take a look at what they have. The local welding shop here has a nice stock of scrap steel that they're willing sell by the pound.
There are several ways to bend tubing without a bender too. One is to fill the tube with sand, cap the ends and bend over something close to the radius you're looking for. |
09-03-2009, 10:17 PM
|  | Motorized Bicycle Senior Member | | Join Date: May 2009 Location: south carolina
| | Re: Frame materials you can bend the cromo tubes on conduit tools
ive bent schedule 80 1" ss pipe with a conduit bender
get a piece of emt and a bicycle frame smack both with a hammer see which is stronger
i agree emt no weld good at all
ive sourced tubing from this company for the build im working on now 4130 ALLOY STEEL ROUND SEAMLESS from Aircraft Spruce
and found it very convenient that they have lots of sizes and thicknesses and they cut it to your order
also the common sizes are cheaper prices |
09-03-2009, 11:27 PM
|  | Motorized Bicycle Elite Member | | Join Date: Jul 2009 Location: tucson
| | Re: Frame materials absolutely not, not even without a motor |
09-03-2009, 11:29 PM
|  | Dealer | | Join Date: Dec 2007 Location: Sacramento
| | Re: Frame materials Hi Fred, I do have, in stock, some VERY nice drop-loop motorbike frames with Whizzer motor mounts built right in. Here is a pic of an old prototype that I put an EZ Motorbike system in.
Mike |
09-04-2009, 12:02 AM
| | Re: Frame materials yeah i wouldnt smash a frame on purpose either i guess shouldve said and a piece of similar thickness 4130 tubing |
09-04-2009, 02:47 AM
|  | Motorized Bicycle Member | | Join Date: Jun 2009 Location: san francisco
| | Re: Frame materials hey im almost done with my bike and i was in the exact same position you are in now, i used galvanized steel, i bought it at the orchard supply down the street because i could not find for the life of me a metal supply shop around my area and when i looked it up it was way too expensive. so i asked the guy that worked there and he told me that it all it was was a steel pipe that had been galvanized (not DOM) and that the only thing to consider was that of you weld galvanized steel it creates a toxic gas but it would be fine if you ground down the area to be welded and welded in an open area, i had no problems whatsoever, and on top of that i used a large 1" conduit pipe bender to bend it, it was hard and required some muscle and help from my friend cuz im pretty skinny but it worked fine and i got some pretty smooth bends believe it or not by bending areas and moving down about 6 inches, you cant tell one bit and best of all i didnt have to buy a $600 pipe roller, i will postt a couple pictures so you can see what i am talking about, oh ya and dont use conduit, it wont work, trust me i considered it before i found the steel and they r pretty close in price, they were actually right next to eachother in the aisle, well i hope this helped you
The Difference Between Art and Reproduction is Innovation
09-05-2009, 10:51 AM
| | Re: Frame materials Guys, I'm always on a tight budget. There's 2 reasons I'm exploring the EMT route and I do actually have some experience making things with the stuff. So to those who flatly say "no way"....do you have any experience working with and making things with EMT ?
My reasons are...
A. Budget
B. Contributing something worthwhile for public consumption
Aric, I think you get where I'm coming from and I'll look into the stuff you used. You said you got it from an orchard supply place....do you remember what it's made for ?
For those wanting to spin this thread into an opportunity to sell a product.....well, kinda makes me not want to do business with you.
MHF |
09-05-2009, 11:02 AM
| | Re: Frame materials It's water pipe look at the threads on one end. |
09-05-2009, 11:12 AM
| | Re: Frame materials Motorhed, you said there was no frame made, that is flatly not true,which is why I made a comment. In addition I am a retired Electrician, and I can assure you that EMT is a poor material for a motorbike, or even ridable bicycle frame.
EMT bends too easily, and by the time you get the zinc off of the steel there is not enuf metal for a good weld, and yes I have made welded projects from EMT but not bicycle frames. My frames are DOM and Normalized Chromoly, BUT in the past I bought steel tubuing at a Metal Shop, and have added new bars to bicycle frames with it. I have also use "Black Iron" gas pipe for some projects and it works ok.
Do business with whomever you wish, but please keep insults to yourself, this is a family board, and respect is the order of the day here.
EMT is not a good material to sustain weight, welding, vibration, nor stress, and is not recommended by any of the builders that I know, motorized or pedal versions.
Select a better material, and you will be happy for it later.
Mike | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:03 PM. | | | Sponsors
