Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle > Board Trackers and Vintage Motorized Bicycles
Electric Board Track Racer
Discussion at Motorized Bicycle Engine Kit Forum in the Board Trackers and Vintage Motorized Bicycles forum. Hi I am new to this forum and I am in the process of putting together an electric board track ...
Old 09-28-2009, 02:04 PM
Default Electric Board Track Racer
Hi
I am new to this forum and I am in the process of putting together an electric board track racer. At this time I have modified and existing frame and have put it together to the point that I have proved the motor chosen has the capability and the system at this point is good for 15 miles at 20mph on level ground including starts. Flat out distances should get close to 20 miles. The motor and speed control are capable of much higher speeds in the range of 40 to 45 mph(I have personally had it to 34mph on old tired batteries that could only put out 4 amps each) but I wanted to keep this considered a motorized bicycle and in Florida that means it has a speed limit of 20mph. In addition I wanted it to have usable range. I am working on regenerative capabilty for hilly areas on the electronics side. I am looking to go into production by the end of the year and will be utilizing a belt drive system, presently it is friction drive which is simple and proved the motor capability, but it is useless if there is any water around. I would like some feed back on the following:
Range- limited by battery technology, could get up to 40+ miles with lithium iron phosphate batteries,
but the cost is substantial. Presently using lead Acid batteries and could possibly increase
range to 30 miles however it would get pretty bulky. NiCad possible but costly also.
Speed - I know when is enough enough, but for the sake of producing something that is afforadable
and reliable there need to be limits. So current range is 15 miles is that acceptable or
would mileage somewhere in the range of 30 to 40 miles be desirable and would that
be worth adding about $500+ to the overall cost of the vehicle.
Side Car- I noticed there were side car board track racers and the side car would make a perfect
place for additional batteries as well as trip storage, any thoughts on that? Lead Acid then
could be utilized to get greater mileage
Drive - Gear, Belt, Friction or Hub Motor- presently I am not using a hub motor but that would make
for a clean installation, however from my research their efficiency is somewhat lacking and
the cost is pretty high for a 500+ watt machine. Keep in mind to climb a 6% grade will require
a long term output of around 900Watts for a 250lb total weight vehicle.
Thanks for any input I get
Old 09-29-2009, 09:21 AM
weekend-fun's Avatar
Default Re: Electric Board Track Racer
Originally Posted by jaeconsult View Post
Hi
Nevr seen a electric BT, You Will be a first!
Side car batterie idea Pros and cons:
Pros:
Carries more batteries
Could look Kewl
Carrie Lugage
Cons:
Wider than normal length,
Hard to store
More wait: slower u go (could get STRONGER motor)
Basicaly, you take up more space riding, more like a car.
Hope this helps!
SAM
well, as "modest mouse" says:
Good news will work its way to all them plans.
visit my website:http://weekend-fun.webs.com/
my youtube: http://www.youtube.com/user/WeekendFunTheBiker
Blog:http://weekend-funs-garage-builds.blogspot.com/
and a GREAT new news source: http://www.newsy.com/
PLEASE join CRU St.Louis if you are near st.louis (or can afford to come here and do rides with us)
Read more at: http://crustlouis.webs.com/
Old 10-02-2009, 12:29 PM
wheelbender6's Avatar
If you like electric propulsion, build it that way. There were plenty of electric cars around in the early 20th century.
Hub motors are trouble free, but a frame mounted DC motor with belt or chain drive may look more authentic.
At any rate, I look forward to your progress reports.
"Don't believe everything you read on the internet. That's how World War I got started" - PS3 commercial
