| Sponsors
| Our Forums | | | | Board Trackers and Vintage Motorized Bicycles Vintage enthusiast share your board trackers and other vintage motorized bicycle ideas and builds and replicas here | Board Tracker or 1910s replica? Dunno... Discussion at Motorized Bicycle Engine Kit Forum in the Board Trackers and Vintage Motorized Bicycles forum. Working on a Huffy Cranbrook, going for that vintage look. The bike came with cream color fenders against a "champagne" ...  | |
11-26-2009, 05:35 PM
|  | Motorized Bicycle Member | | Join Date: Nov 2009 Location: Florida
| | Board Tracker or 1910s replica? Dunno... Working on a Huffy Cranbrook, going for that vintage look. The bike came with cream color fenders against a "champagne" color frame. Looks so nice that way! In spite of y'all telling horror stories and giving warnings about the dreaded fender mishaps, still wondering if I can get away with it. Thoughts? |
11-26-2009, 08:47 PM
| | Re: Board Tracker or 1910s replica? Dunno... as long as you beef up the fender supports they should be fine. you can get some Wald fender struts for cheap, and that should do it.
if you want a vintage looking cranbrook, use it for a boat anchor in the atlantic for a coupla weeks...  |
11-26-2009, 11:29 PM
| | Re: Board Tracker or 1910s replica? Dunno... The struts are not stamped metal cheapies. They are round rod, chromed, attached with bolts and backing plates. I feel pretty good about them.
Soon as I can post pix, I'll put some up. Hope to be done with the build in couple days.
doc  |
11-27-2009, 08:43 PM
|  | Dealer | | Join Date: Dec 2007 Location: Sacramento
| | Re: Board Tracker or 1910s replica? Dunno... Doktor, does the front wheel have 2 braces up to the fender, or only one? If only one, it will not matter if tin, wire, or structural steel, you will find that you need 2 braces on the front fender, in addition to the tab.
As we have seen here, there are 2 ways to decide if you need 2 braces, the easy way and the hard way.
Those who have chosen the hard way will never forget it, including Cliff in Fairfield CA who got a trip to the Hospital, and some painful recovery time.
As always, the choice is yours.
Mike |
11-28-2009, 12:39 AM
|  | Motorized Bicycle Elite Member | | Join Date: Sep 2008 Location: The Belly of the Beast
| | Re: Board Tracker or 1910s replica? Dunno... Mikes right! If it breaks, before you know it your broken. |
11-28-2009, 10:17 PM
| | Re: Board Tracker or 1910s replica? Dunno... Mike....point taken, I like to err on the side of caution. The front fender has 2 tabs going both sides of the fork arch, and the rods on either side at 3-o-clock position on the trailing side. Top of fender hangs out only a couple inches past the forks and is surrounded by a caliper brake I added for extra stoppage. It's also a stamped fender with ridges and grooves along both edges for stiffness. I'm more confident about that design than the thin rolled fenders you see sometimes. Just the same, when I get the bike finished and take a couple of "shakedown" rides I'll be watching the whole setup for drift and will remove them ASAP if they appear to wobble too much at speed. My old guy bod is sorry enough without adding more injuries.
Doc |
11-30-2009, 06:46 PM
| | Re: Board Tracker or 1910s replica? Dunno... UPDATE...Cranbroook is built and pedal-tested...ready for fuel and road test!
Doc |
12-01-2009, 06:57 PM
| | Re: Board Tracker or 1910s replica? Dunno...  Gassed up and road tested...coupla tweaks and it's good! |
12-02-2009, 03:27 AM
| | Re: Board Tracker or 1910s replica? Dunno... interesting seat post action whats holdin it? |
12-02-2009, 11:35 AM
| | Re: Board Tracker or 1910s replica? Dunno... Well...being a Florida guy, I went to West Marine!
First pic: Flipped the clamps on the seat mount to make the seat sit lower on the post.
2nd pic: Used a 1" boat rail straight socket mount. Works with the frame angle just right. (You can also get them in 60-degree tilt.) Held in place with 4 heavy duty stainless rubber sheathed clamp/clips (Ancor Marine), high grade bolts and globs of threadlock.
3d pic: Seat post held in place by 2 socket set screws on the rail mount. I figgered if they will hold you hangin' over the boat rail in a gale, it'll hold my lardazz on the bumps. So far, ees good.
Doc | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 07:18 AM. | | |
