| | | 4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine | Torque converter Discussion at Motorized Bicycle Engine Kit Forum in the 4 Stroke Bicycle Engines & Kits forum. It may be tough to mount the CVT remotely as it needs to bolt to the crankshaft. It has a ...  | |
04-30-2009, 12:26 PM
|  | Vendor | | Join Date: Dec 2008 Location: Longneck, DE
| | Re: Torque converter It may be tough to mount the CVT remotely as it needs to bolt to the crankshaft. It has a clutch bell built into it. |
04-30-2009, 12:37 PM
|  | Motorized Bicycle Elite Member | | Join Date: May 2008 Location: CT, U.S.
| | Re: Torque converter just read your post. Great lookin' Bike! What I am thinking for that is an "L" plate that mounts to the seat post and CVT mounts to it with 2 shafts coming out. (drive and driven) Really dunno if it will work but always wanted to try one. Have 2 Honda's and they are a joy.
__________________ Quote:
Originally Posted by NEAT TIMES looking In The Sky, May See Dan Flying By!! Ha Ha Ron | I want 2 ride my bicycle |
05-06-2009, 10:23 PM
|  | Motorized Bicycle Newbie | | Join Date: Jun 2008 Location: Fort Worth, Tx.
| | Re: Torque converter I've used Comet converters on mini bikes and my diesel powered GS850. They are okay, but rob a good amount of horsepower due to friction losses. A two speed centrifugal clutch would be nice, but you would have to gear down say, 50% before the clutch to reduce rpm, double the torque and reduce the 2 speeds chain velocity. Without an oil bath for the chains, they would wear out fast at engine crankshaft speed.
Cris |
08-26-2009, 07:56 AM
| | Motorized Bicycle Senior Member | | Join Date: Jul 2009 Location: usa
| | Re: Torque converter |
10-29-2009, 04:53 PM
| | Motorized Bicycle Newbie | | Join Date: Aug 2008
| | Re: Torque converter Go to Grainger dot com
search for this.
Steel Reducer Bushing, Inside Diameter 5/8 Inch, OD 3/4 Inch, Length 1 1/4 Inches, Zinc Plated, With 3/16 Inch Open Slot for Keyway and Setscrew
This way I guess you can mount 3/4 Comet 30 CVT on 5/8 shaft engine.
I have the same idea use Harbor Freight 2.5 HP engine with TAV2. It's good deal for $87 (with coupon) to get engine like this.
I don't know how heavy engine is. I guess I will try to find out next time when I go to the store. |
10-30-2009, 03:51 PM
| | Motorized Bicycle Elite Member | | Join Date: Apr 2009 Location: Alabama
| | Re: Torque converter I'm not sure about the comet CVT, but some of the cheap scooter cvt's have another gear reduction between the driven pulley and the output sprocket. The one I used reversed the rotation of the output sprocket from the engine direction, which meant that the tire would turn backwards. I spent about a month trying to get all the bugs worked out. I ended up with 2 good rides before everything went wrong. I would suggest paying attention to this when choosing a cvt. If the pics of the cvt show the output sprocket off center from driven pulley, you will have your work cut out for you. |
10-31-2009, 01:18 PM
| | Re: Torque converter I got idea from my Go Kart. People often upgrade go kart with comet CVT.
And also you may not need the reduction box. Here is the calculation with custom order 60 teeth sprocket for #35 chain, base on 26 inch bicycle
Low speed is 10.4 mile/hour (TAV2 engage at 2200 RPM with low range radio 2.7:1)
High speed is 50.9 mile/hour (3600 RPM with high range radio 0.90:1)
If you mount this way is very simple. Only need engine,CVT, chain, custom sprocket no need jack shaft or reduction box.
The down side is you need pedal bike to 10 mile/hour before engage CVT. |
10-31-2009, 02:26 PM
| | Motorized Bicycle Senior Member | | Join Date: Sep 2009 Location: Mississippi
| | Re: Torque converter Quote:
Originally Posted by efinitylove Go to Grainger dot com
search for this.
I don't know how heavy engine is. I guess I will try to find out next time when I go to the store. | Mine weighs 22# without gas or oil out of the box.
Elmo
All times wasted wots not spent ridin
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 04:55 PM. | | | Sponsors
