Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
titan kill switch and other stuff
Discussion at Motorized Bicycle Engine Kit Forum in the 4 Stroke Bicycle Engines & Kits forum. So I got the titan to run the way i want it, but still haven't figure out how to ...
Old 04-29-2009, 02:02 AM
Default titan kill switch and other stuff
So I got the titan to run the way i want it, but still haven't figure out how to connect the kill switch yet. After I'm done with my ride, i would have to use the push button in the back of the motor.
does the titan comes with transmission fluid already? I see the drain plug for the tranny/clutch but can't find where to fill it up. I would think it comes prefilled with fluid already.
Is there a way to get electricity out of the titan? any wires tuck away that i can use if i need to find a power source?
.... other than that i'm having fun with the MB about 3hrs total now.... it is one **** of a ride. Taking corners is awesome with the engine on the rear wheel....
Old 04-29-2009, 11:57 AM
Bikeguy Joe's Avatar
Default Re: titan kill switch and other stuff
I'm bumping this one up......Titan owners can you help?
Old 04-29-2009, 12:45 PM
azbill's Avatar
you could probably call duane and ask him
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 04-29-2009, 07:03 PM
Splice one of the wires from the throttle kill switch, into the engine kill switch wire. Ground the other wire.....thats it. I used the screw holding the engine kill switch as a ground. Gear box will come pre-filled and it will puke oil out for the first hundred miles or so. Be sure to check engine oil as mine was low when I recieved it............. There is no power source on the Titan--your stuck with batteries......hope this helps.
Old 04-29-2009, 10:50 PM
anyone has dax's number? my pull start assembly broke today. and I need a couple other parts as well... thanks guys
Old 04-29-2009, 10:58 PM
fairracing31's Avatar
303-459-2780
thatsdax@yahoo.com
bicycle engine kit, bike engine, bicycle engine, bicycle motor
Old 04-30-2009, 01:24 AM
Thanks fairracing31. After i made the post, I went to his site and found his number :-)...
thatsdax has great customer service guys.
Old 05-01-2009, 01:01 PM
patiently awaiting my parts...
