need clutch help for Storm 49cc 4 stoke I'm brand new to this,instructions have been misleading such as their listed one piece crank is actually sent as 3 piece and throttle attachment takes drilling a hole in bottom of handlebar when really its the top,all those kinks are worked out.........So problem is instruction tell me to disassemble my left side handle bar shifter to use as my clutch and shows I hook the opposite end to the left side gear box of my 4 stroke.I have thoroughly scanned my motor and it has no manual clutch lever to attach the wire to.Upon reading others threads over and over people state there 4 stroke is an automatic and since I don't trust these horrible incomplete instructions they gave I wonder if I ever needed to dissemble my shifter in the first place or for that matter manually pedal to 2 mph then drop the clutch or I'll wear out my clutch it said if not peddling it up to speed.Yes I did download the 4 stroke instructions I have checked 3 times.
Does anyone know if the 2009 Storm 49cc 4 stroke has an automatic clutch and I can forget the instruction,and so you know throttle is hooked up and ready,so clutch ,oil and gasoline is all I'm away from to start my bike.So if its an automatic then there is no need to pedal correct.Please me,Thank you |
