Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
math help, gearbox equasion,
Discussion at Motorized Bicycle Engine Kit Forum in the 4 Stroke Bicycle Engines & Kits forum. ok so if i have a hoot gearbox and a 44t rear sprocket, what rpm is it at 45kph? what ...
Old 11-17-2009, 07:57 AM
linnix13's Avatar
Default math help, gearbox equasion,
ok so if i have a hoot gearbox and a 44t rear sprocket, what rpm is it at 45kph? what speed would be 7500rpms? thanks,
and ps i know i suck at math, thats why im asking for help!
i'd rather have a bottle in front of me than a frontal lobotomy,
-linnix13(at)gmail,com
Old 11-18-2009, 10:09 AM
linnix13's Avatar
Default Re: math help, gearbox equasion,
ok nevermind i will go try to figure it out myself, thanks anyways
Old 11-18-2009, 11:14 AM
Ilikeabikea's Avatar
Dang that kind of math is making my head hurt. .................
http://www.galtx.org/
http://bdconner.com
Old 11-18-2009, 11:38 AM
MotorbikeMike's Avatar
Dealer
Hi Linnin, I do not have a box in front of me they are packed in the storage.
Take the small gear on clutch and divide it into the bigger gear it runs in, save that number: (A)
take the gear on that shaft and divide it into the number of teeth on the gear it drives, save that number (B)
take your output sprocket and divide it into the rear sprocket, save that number. (C)
now multiply (A) times (B) and the result times (C)
NOW that is your total gear ratio (final drive ratio).
RPM vs Speed?
now you got to do the circumference of the rear tire, and figure out how far it travels (how many revs for one mile)
Or just cheat and use a calculator like I have on my page here Simpson Motor Bikes
(expect a PM I need to figure shipping)
Mike
www.ezmotorbike.com www.simpsonmotorbikes.com
Home of the 08 Racer and
NEW Model 10 production bikes
Old 11-18-2009, 03:36 PM
Kevlarr's Avatar
42, it's the answer to life, the universe and everything.
Old 11-18-2009, 03:37 PM
linnix13's Avatar
yes yes we have all seen Hitchhiker's Guide to the Galaxy,
Old 11-18-2009, 04:59 PM
RebelMoby's Avatar
He is wrong anyhow linnix13 -
Doing the hokey-pokey is what it is all about!
Old 11-20-2009, 07:58 PM
Quenton Guenther's Avatar
Dealer
Hi Linnix13,
Here are a few numbers you might find interesting. All the numbers are from the EZM Q-Matic prototype bikes. Speeds & RPMs supplied via electronic speedometer & tachometer. The stock ratio also verified on Dyno tests. The test were conducted using the HS 49 CC 4 stroke motor after break-in.
Actual higher speeds were recorded but not with optional ratios available [12.3 X 1 @ 8000 = 50.3 MPH]. The high speed HS motor also used the EZM tuned flex pipe system, special K & N intake breather, and adjustable main jet. EZM does not offer the adjustable main jet or K & N filter, only the tuned flex pipe system. The K & N air breather is available via K & N dealers.
26" bike @7500 RPMs [165 lb rider]
Stock EZM ratio 14.68 X 1 = 39.5 MPH
Optional EZM ratio 13.31 X 1 = 43.5 MPH
Optional EZM ratio 14.07 X 1 = 41.2 MPH
Optional EZM ratio 15.52 X 1 = 37.3 MPH
Optional EZM ratio 15.97 X 1 = 36.3 MPH
Optional EZM ratio 16.46 X 1 = 35.2 MPH
Chances are your drive is between 18.5 to 21 X 1, depending on rear sprockets and or which series of gearbox and won't be able to reach the higher speeds of the EZM drive system.
18.5 X 1 = 31 MPH
21 X 1 = 27.6 MPH
Information on the G4 drive with the 5 X 1 primary and a 44 tooth rear is 22 X 1 [26.3 MPH @ 7500 RPMs], with 48 rear sprocket is 24 X 1 [24.1 MPH], and 56 rear sprocket is 28 X 1 [20.7 MPH]. The G4 ratios are based on the advertized 5 X 1 primary numbers.
Hope this information is what you are looking for.
If looking for Galaxy numbers & ratios either multiply by 42 or divide by 42 to arrive at warp speeds.
Have fun,
Quenton
www.ezmotorbike.com
  #9 (permalink)
Old 11-20-2009, 08:06 PM
linnix13's Avatar
Originally Posted by Quenton Guenther View Post
Hi Linnix13,
Chances are your drive is between 18.5 to 21 X 1, depending on rear sprockets and or which series of gearbox and won't be able to reach the speeds of the EZM drive system.
18.5 X 1 = 31 MPH
21 X 1 = 27.6 MPH
Have fun,
my top speed is 45kph, but if i go with like a 17 x 1 i will have so much lower torque, i want the power as apose to torque, 45kph is the fastest i wanted to go, so the gearboxes with those insanely high speeds is not what i want, torque is my needs,
  #10 (permalink)
Old 11-20-2009, 08:25 PM
Banned
PLEASE NOTE THIS WAS DONE FOR A JACKSHAFT BUT FOLLOW THE FORMAT FOR OTHERS.
Ok i haven't seen this put together in 1 place so i'll start here.
We will take a deep look at speeds and Rpm's the best way.
Start with the Wheel and work backwards.
In order to hit the speed we want and not kill our motor and not peddle too fast we need to consider all these figures.
I have some math to do here and will post calculations soon.
Any help from other members is appreciated.
I will start with wheel RPM and ground speeds.
Wheel RPM TO GROUND SPEED.
26" WHEEL - .5" FOR squishing under pressure.
Circumfrance = 80.11061266653972 inches.
feet in a mile = 5280 feet
Inches in a mile = 63360 inches
# of wheel rotations per mile =
63360 / 80.11 = 790.91 rotations per mile
Desired Take off Speed = 5 MPH
790.91 X 5 = 3954.56 rotations per hour
3954.56 / 60 min = 65.91 RPM
Wheel speed = 65.91 RPM at 5 MPH
Desired Max Speed = 45 MPH
790.91 x 45 = 35590.95 rotations per hour
35590.95 / 60 min = 593.1825 rpm
wheel speed = 593.1825 RPM
So that is a nice range.
Not that we need to go that slow or fast.
Just baseline calculations to show extreme
min and max wheel rpm.
The main thing to consider right now is what
is the slowest the bike can move when the clutch
engages without stalling the engine.
= Drive Gear RPM divided by Overall Gear Ratio
This = the required Wheel rpm to not stall engine.
example:
HT motor 4:1 ratio internal gearing
1000 rpm motor speed.
1000 / 4.1 = 243.9024 RPM of 10T Drive Gear
10T Drive / 36T Driven = 3.6 : 1 ratio
243.9024 / 3.6 = 67.75 RPM
This means if your wheel is not rotating 67.75
revoloutions in a min your engine will stall if it is
running at 1000 rpm
ENGINE RPM VS WHEEL SPEEDS AND GEARS.
I will use some standard Sprocket configs to
figure out where we want to start.
So lets say 32T is the largest sprocket we have
on the Rear Cartrige or Freewheel.
This will be our lowest gear we need to get 5 MPH
at just above engine idle.
32T Sprocket speed = 65.91 RPM at 5 MPH
For the JACKSHAFT we need to figure the nessessary rpm
of the next sprocket.
Which would be the Crank Sprocket at the Front Freewheel
that the bicycle chain is on.
We will call it sprocket 2 = "S2"
Since it is available we will figure on 44T for "S2"
Gear ratio = 44 / 32 = 1.375 : 1
65.91 / 1.375 = 47.935 Rpm at 44T at 5 MPH
Now lets figure what our jackshaft speed will need to be.
Engine Rpm at takeoff = 1000RPM
1000 / 4.1 = 243.91 RPM
243.91 / 47.953 = 5.086 : 1 ratio
Now things are a little more complex here because we have
1 speed for the Jackshaft and 2 gears on it.
This means we need to work out 2 ratios that get the
44T sprocket moving at 47.953 RPM.
We cant solve for 2 variables so we will have to pick 1 sprocket.
We will start with the 17T sprocket on the left side of the Jackshaft.
Because it is available.
17T / 10T = 1.7 : 1 ratio.
243.91 / 1.7 = 143.4764 rpm at the 17T and Jackshaft
143.4764 / 47.953 = 2.99 : 1 ratio. so lets say 3:1
We also have another unknow sprocket in the system.
The 2nd front crank freewheel sprocket is smaller than the 44T
For chain interference we want some clearence.
Now the 36T is used
36 / 3 = 12
So a 12T would be optimal with the starting speed of 5MPH
The 12T isn't available.
Chainring sprockets are easy to come by so we could go a little smaller
than the 36T or a little bigger than the 44T.
There is a 48T available.
11T is pretty close lets look at it.
36 / 11 = 3.27 ratio
143.4764 / 3.27 = 43.8765 RPM
44 / 32 = 1.375 : 1
43.8765 X 1.375 = 60.3301 rpm of wheel.
60.3301 X 60 = 6319.806
6319.806 / 790.91 = 7.9905 MPH
So after all that heres how the cookie crumbles.
WITH MOTOR RPM = 1000
10T drive at motor at 243.91 RPM
17T at jackshaft at 143.4764 rpm
11T at jackshaft at 143.4764 rpm
36T at Front Freewheel at 43.8765 rpm
44T at front Freewheel at 43.8765 rpm
32T at wheel at 60.3301 rpm
Minimum peddeling speed = 7.9905 mph
Lets figure the max speed.
Tuned Engine RPM = 6000
6000 / 4.1 = 1463.41 rpm at 10T
1463.41 / 1.7 = 860.832 rpm at 17T
860.832 rpm at 11T
860.832 / 3.27 = 263.2514 rpm at 36T
263.2514 at 44T sprocket
So in the same gear the 32T at the rear wheel
263.2514 x 1.375 = 361.97 Rpm at rear wheel
361.97 X 60 = 21718.2405
21718.2405 / 790.71 = 27.46 mph
So the low gear range is from 7.9905 MPH to 27.46 MPH
Remember we can shift now.
High gear lets say = 11T its pretty std on freewheels.
Now things get easier.
44 / 11 = 4 :1
263.2514 X 4 = 1053.0056 rpm
1053.0056 X 60 = 63180.36
63180.36 / 790.71 = 79.90 mph
Wow thats all i can say.
If you had a long enough run you could get there.
Specified engine rpm = 4500
4500 / 4.1 = 1097.56 rpm at 10T
1097.56 / 1.7 = 645.62 rpm at 17T and 11T
645.62 / 4 = 161.25 rpm at 44T
161.25 X 4 = 645.62 rpm at 11T rear freewheel
645.62 X 60 = 38737.2
38737.2 / 790.71 = 48.99 MPH.
STILL VERY IMPRESSIVE.
WITH 24T REAR SPROCKET
161,62 X (44/24) = 296.30
296.30 X 60 = 17778
17778 / 790.71 = 22.48 MPH
tUNED ENGINE RPM = 6000 RPM
161.25 X (44/18) = 394.16
394.16 x 60 = 23650
23650 / 790.71 = 29.90 MPH
vERY EASY TO SEE THE EFFECTS OF THE JACKSHAFT.
THE UNANSWERED QUESTION IS HOW MANY RPM DO WE
REALLY GET WITH THE TUNED ENGINE.
AND EVEN AT 4500 RPM THE SPEED GETS PRETTY HIGH.
iTS A MATTER OF HOW QUICKLY CAN WE GET TO SHIFTING SPEEDS
tHE 79.90 WOULD REQUIRE 7 TO 8 SHIFTS.
PLEASE ALSO NOTE IT IS MOST LIKLY INTENDED FOR THE 36T CHAINRING
TO DRIVE THE REAR FREEWHEEL.
I CALCULATED THIS THE OTHER WAY AROUND WHICH MAKES THINGS ALOT FASTER.
TO CLARIFY THE 11t JACKSHAFT SPROCKET SHOULD NORMALLY GO TO THE 44T CHAINRING.
tHAT MAKES A 4:1 REDUCTION.
WITH THE 11T GOING TO THE 36T WE HAVE A 3.27 REDUCTION.
tHAT MAKES A BIG DIFFERENCE.
bUT DEPENDING ON HOW NUTTY YOU WANT TO BE.
I DON'T SEE WHY YOU COULDN'T RUN THE FRONT FREEWHEEL EITHER WAY.
iT'S A MATTER OF HOW YOU PUT THE SPROCKETS ON.
NOW I REALLY UNDERSTAND WHY THESE JACKSHAFTS ARE LIKE GOLD.
LOOK AT WHAT IT ACCOMPLISHES.
GENERALLY IF CONFIGURED CORRECTLY.
YOU WOULD NEVER NEED TO RUN THE ENGINE AT HIGH RPM
HTML code is On
