Originally Posted by GearNut There is a specific puller that is used to remove the clutch. It also removes the little crankshaft gear.... |
No there isn't- he is not talking about a 2 stroke.
Once you get the bolts and washer off- should slide off. You may need a puller like ocscully said, but you should not.
