ok, so the $199 4stroke motorkit arrived today. good.
but here's what i'm facing:
once this chain loosens up, its going to start breaking teeth. not good. as you can see in the 2nd pic, its already on the loose side. and it hasnt been run yet.
someone told me theres a post or thread where someone has installed a spring loaded tensioner inside the casing.....does that sound familiar to anyone? i am unable to find it.
if you follow the tip of my finger to just under the top chain, thats the farthest forward of the casing anything to mount one can be drilled, before you get into other stuff.
i may be able to drill a slot (to adjust up or down) in the back, and run a regular roller bearing wheel
