Re: 4 Stroke Clutch I think the simple answer to your question has to do with the engine design.The inexpensive Chinese 2-stroke motors are purpose built to be mounted into a bicycle frame and used accordingly. The motors used in the 4-stroke kits are commercial/industrial small engines designed to be used in a varity of installations on generators, on lawn and garden equipment, etc. The use of these engines on bicycles probably was never a consideration. The type of clutch you have on the 2-stroke is not available for the up right 4-strokes. You could probably? bump start a 4-stroke with the EZ Motorbike Silent Drive (tensioned belt drive system) But I don't have first hand experience with this, perhaps one of the folks who have one of these kits will chime in and comment on this? Another example of a tensioned belt drivetrain would be the Whizzer, and they are a bump-start 4-stroke application.
ocscully |
