Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
3 speed jack shaft
Discussion at Motorized Bicycle Engine Kit Forum in the 4 Stroke Bicycle Engines & Kits forum. ...because then he wouldn't have the advantage of a three speed transmission....
LinkBack (3) Thread Tools Display Modes
  #11 (permalink)
Old 09-26-2009, 08:40 PM
HoughMade's Avatar
Default Re: 3 speed jack shaft
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
  #12 (permalink)
Old 09-26-2009, 11:15 PM
Maybe the answer is right before my eyes but Im not seeing it. Im not saying the shaft coming out of the motor, the shaft coming out of the gear box. Why is it that he went to a drive sprocket on right side then back to the left side to the drive wheel chain? From the pics it looks like he could have driven the drive wheel chain directly off of the shaft coming out of the gear box. The gear box contains the 3 speed transmission correct? The gear box stays on Im not mentioning to do away with it....how do you shift that gear box between 1st, 2nd and 3rd?
  #13 (permalink)
Old 09-26-2009, 11:50 PM
diceman2004's Avatar
bandito , that hub ( IS ) the 3 speed . and it has to be driven from the right side as it would if it were driven by the pedals . it only works one direction and is likely a coaster brake hub , so it must be driven from the right side of the bike . it shifts by a small chain that comes out of the hubs axle . it has 3 positions , planetary gears .
the gearbox on the side of the motor is only a gear reduction . it doesn,t shift .
  #14 (permalink)
Old 09-27-2009, 12:16 AM
OK I finally understand, I feel humbled. I thought you could actually shift it from 1 speed to another. TY Diceman.
  #15 (permalink)
Old 09-27-2009, 04:34 AM
actualy i could be wrong about the gearbox on the side of the motor . its pretty big . earlier in the thread theres mention of a cvt but he says its chain drive it may also have a few gears , 2speed clutch or something , i don,t know . but anyways , thats why the chains are the way they are .
  #16 (permalink)
Old 09-27-2009, 09:42 AM
Whats the purpose of a gear reduction gearbox if you need to further reduce the ratio with additional sprockets? Im bull headed Im gonna get this answered.
  #17 (permalink)
Old 09-27-2009, 09:57 AM
HoughMade's Avatar
The gearbox on the the engine itself is not a CVT- it reduces the engine speed at a ratio of 3:1 meaning that that the output shaft is turning 1/3 the speed of the engine. That is fine if you just want to run that to the rear wheel, but there will be one, fixed ratio- now additional ratios. Why additional ratios? Because the 3:1 reduction is fine for cruising, but very, very sluggish at lower speeds- takes for ever to accelerate. It would be so much nicer if there was some way to have a lower ratio so the engine could turn faster, in its power band, at a slower sped, then some way to change ratios to and intermediate range to continue decent acceleration, then a final ratio to cruise at with the engine not screaming at a very high speed.
Bingo- the 3 speed transmission. Think of it this way- with that three speed, you have the equivalent of 3 rear sprockets- something like an 70 tooth for acceleration at a lower speed, a 60 tooth for intermediate and a 48 tooth for cruising. However, you get all this just in that little three speed hub.
  #18 (permalink)
Old 09-27-2009, 01:53 PM
Ok Hough I appreciate your input, the output shaft off of the gear box turns at 1/3 the speed of the engine ok. In my mind I know the purpose of the gear box and thats what it does. The purpose of the other 3 sprockets is to change that 3/1 ratio correct? (plus theres the sprocket on the wheel) How does this bike change ratios without changing a sprocket to a different size? I now know why he didnt put the drive chain to the rear wheel directly to the output shaft coming from the gearbox. What is the final ratio between the engine rpm and the rear wheel sprocket with this setup? How does this bike change from a 70 to a 60 then a 48 tooth gear ratio? Im starting to feel stupid.
  #19 (permalink)
Old 09-27-2009, 04:49 PM
urrrggggg . bandito . the bicycle hub that he is running between the motor and the rear wheel is a ( 3 speed hub ) . all of the gears are inside that hub . i,m not sure what the gear ratios are ,but lets say for arguement sakes 1st gear is 3/1 , 2nd gear is 2/1 and 3rd gear is 1/1 . the picture attached is what the inside of that hub looks like . i take it you never seen one of these before , they were very common when i was a kid .
  #20 (permalink)
Old 09-27-2009, 05:05 PM
oops and before you ask . the gears are changed by a small chain that comes out of the center of the axle hooked up to a gear lever by a cable
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f37/3-speed-jack-shaft-11499.html
Posted By For Type Date
ratrodbikes.com • View topic - drivetrain jack shaft help This thread Refback 10-27-2009 02:47 PM
Everything about jackshaft - Yahoo! This thread Refback 10-16-2009 05:13 PM
ratrodbikes.com • View topic - drivetrain jack shaft help This thread Refback 10-04-2009 07:33 PM
