| Sponsors
| Our Forums | | | | DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds | will this motor work? Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. I seen a video on YouTube where it said not all motors will work. This is the only one I ...  | |
05-03-2009, 10:34 AM
| | Motorized Bicycle Member | | Join Date: Apr 2009 Location: Indiana
| | will this motor work? I seen a video on YouTube where it said not all motors will work. This is the only one I have at the moment although I think a buddy has another weed eater that has a broken head. He would probably give it o me for free... |
05-03-2009, 10:35 AM
| | Re: will this motor work? If you guys need any more pictures of different parts of the motor just let me know. I will post anything I need to get help. |
05-03-2009, 02:21 PM
| | Re: will this motor work? bump.. anyone have any idea? |
05-03-2009, 05:58 PM
| | Re: will this motor work? That should be a direct drive if it's like all the Homelites I have seen. It will work, but you'll need to use some form of lifting mechanism so you can pedal with the engine off. That should be no problem to build.
05-03-2009, 07:14 PM
| | Re: will this motor work? Quote:
Originally Posted by Bikeguy Joe That should be a direct drive if it's like all the Homelites I have seen. It will work, but you'll need to use some form of lifting mechanism so you can pedal with the engine off. That should be no problem to build. | this all a new language to me so I'm going to have to do some research.. |
05-03-2009, 07:22 PM
| | Re: will this motor work? That means there is no clutch, so in order to stop without killing the engine, you'll have to make some provision to lift the engine off the wheel/tire, since that type of engine would require a direct drive friction wheel arrangement.
05-03-2009, 09:57 PM
| | Re: will this motor work? sounds like allot of modifications that I have no idea about... |
05-04-2009, 12:40 AM
| | Motorized Bicycle Elite Member | | Join Date: Feb 2009 Location: Momence, IL
| | Re: will this motor work? Quote: |
Bikeguy Joe is talking about a basic friction drive... the simplest way to motorize a bike. Quote: |
| If you intend to put a weed eater motor on a bicycle, of course you will have to do "allot of modifications" [sic]. You came to the right place if you want to find people who can help you make that happen. |
05-04-2009, 09:09 AM
| | Re: will this motor work? It's actually pretty easy to make a friction drive...there is a lot of help in the DIY forum.
Go for it!
05-04-2009, 09:11 AM
| | Re: will this motor work? If you want easy but not cheap (the two don't seem to go hand in hand) then go for the Titan.
A two stroke in frame kit is fairly easy to install and only 100 dollars.
A friction drive with a weed wacker engine is really cheap, and the work involved is not too much more (some will say less) than the in frame option.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 01:45 PM. | | |
