| | | DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds | new plans for 80cc bmx with shifter Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. hey guys, while camping in donnybrook for a few nights with freinds, i was able to ride a few quad ...  | |
10-17-2009, 09:03 PM
|  | Motorized Bicycle Member | | Join Date: Oct 2009 Location: australia
| | new plans for 80cc bmx with shifter hey guys, while camping in donnybrook for a few nights with freinds, i was able to ride a few quad bikes and 2 wheelers. anyway i came home and went for a ride on my 31cc ryobi bike and i was hating it, i guess when i was riding them 400cc quads around something must have triggered in me and now im addicted to power. well my new project is going to go like this:
80cc chinese kit used on 20 inch bmx with the kit sprocket going to the left side of the pedal shaft and on the right side of the pedal shaft going to a 15 tooth bike sprocket then to the back hub with a derailleur setup from a mountain bike, 1st gear i want to be supper low so i can start riding on a hill and the 5th gear i want to be overdrive so when im upe in exmouth i can fang along the ocean roads to get to the beach.
now your asking why a bmx? well i think its worth the trouble because i want something sporty, that i can do tricks and stuff like that, basically i want to make a equivalent of a bmx motorbike.
this is were im going to mount the engine but with front tube supporting tubes, this is not my bike
I FIX MORE THAN I RIDE |
10-17-2009, 10:41 PM
| | Re: new plans for 80cc bmx with shifter you could try looking into BMX cruisers. if you could find a 24 incher that the motor would fit into, you can get all kinds of good parts for it, it'd be a little bigger, and you wouldn't have to chop it all up to make it work. |
10-17-2009, 10:54 PM
|  | Motorized Bicycle Newbie | | Join Date: Oct 2009 Location: athens ga
| | Re: new plans for 80cc bmx with shifter Quote:
Originally Posted by bairdco you could try looking into BMX cruisers. if you could find a 24 incher that the motor would fit into, you can get all kinds of good parts for it, it'd be a little bigger, and you wouldn't have to chop it all up to make it work. | good idea . Torqin, if you want to go this route ... I have an early 80's Murray X24 frame and fork that I would sell ya for relatively cheap . I may even be able to dig up a set of 24 wheels . I'm on old school BMX nut too :P
10-18-2009, 02:29 AM
Originally Posted by treyverb good idea . Torqin, if you want to go this route ... I have an early 80's Murray X24 frame and fork that I would sell ya for relatively cheap . I may even be able to dig up a set of 24 wheels . I'm on old school BMX nut too :P | its okay, i live in australia anyway, thanks for the offer. hardwaste pickup is on now so i will look for a bike there
10-19-2009, 07:55 PM
| | Motorized Bicycle Senior Member | | Join Date: Jan 2008 Location: England
| | Re: new plans for 80cc bmx with shifter My criteria for my ongoing build is very similar, it needs to be tough enough and small enough to be able to hoon around. So like the other guys have suggested to you, I have gone with a 24" dirt jump bike build, the frame is a saracen amplitude 1, the engine that is going in is a Cag (pocket bike motor). the cranks I am using are BMX 3 piece cranks (gusset pigmeys) and the Forks i plan on using are a long travel 150mm single crown (manitou stance blunts). It is to be a single speed, geared similar to a BMX as the engine will never have the torque my legs do but the engine itself should propel the bike to 35-38mph with the gearing i have worked out.
With a few alterations in spec I think this would be the kind of build your looking for? |
10-22-2009, 09:51 AM
Originally Posted by pedro5189 My criteria for my ongoing build is very similar, it needs to be tough enough and small enough to be able to hoon around. So like the other guys have suggested to you, I have gone with a 24" dirt jump bike build, the frame is a saracen amplitude 1, the engine that is going in is a Cag (pocket bike motor). the cranks I am using are BMX 3 piece cranks (gusset pigmeys) and the Forks i plan on using are a long travel 150mm single crown (manitou stance blunts). It is to be a single speed, geared similar to a BMX as the engine will never have the torque my legs do but the engine itself should propel the bike to 35-38mph with the gearing i have worked out.
With a few alterations in spec I think this would be the kind of build your looking for? | great, this is a very sturdy plan you have set out for yourself, i recommend using an 80 cc bike motor instead of a pocket bike motor, you will need to have about a 23 or 25 to one gear ratio for any chances of it working but a 80cc bike motor already has a 4 to one ratio in the engine itself oh and not to mention a clutch, that could come handy in hooning, pocket bike motors are fun but they lack reliability, there built to ride only tiny amounts and are built like crap so i would recommend a 80cc engine with a few mods like rubber engine mounts, chain guides and a tuned exhaust in the end its all up to how you want your bike to turn out
10-22-2009, 06:48 PM
Originally Posted by TorqinDirty great, this is a very sturdy plan you have set out for yourself, i recommend using an 80 cc bike motor instead of a pocket bike motor, you will need to have about a 23 or 25 to one gear ratio for any chances of it working but a 80cc bike motor already has a 4 to one ratio in the engine itself oh and not to mention a clutch, that could come handy in hooning, pocket bike motors are fun but they lack reliability, there built to ride only tiny amounts and are built like crap so i would recommend a 80cc engine with a few mods like rubber engine mounts, chain guides and a tuned exhaust in the end its all up to how you want your bike to turn out | That would be ideal but to get the 80cc engines over here is not cheap, particularly recently with how bad the pound is against the dollar. My perfect engine would have been a morini but they are far to expensive for my budget. I also was given a pocketbike motor for free, and with the addition of a 3.25:1 reduction gearbox that cost me all of £13 (around $18 i think) delivered it has made it a very viable powerplant for me. As with the clutch I always wanted a centrifugal (I only want brake levers on the handlebars) which this has so that has also been ideal. I would say (having almost no experiance of either) that because of there origins are going to be similarly unreliable but with the saved money from getting a free engine I am planning on rebuilding the engine from scratch with the 52cc bore and stroked crank. On top of that i will port match it and replace all the chinese bearings with there swedish counterparts. |
10-22-2009, 07:59 PM
Originally Posted by pedro5189 That would be ideal but to get the 80cc engines over here is not cheap, particularly recently with how bad the pound is against the dollar. My perfect engine would have been a morini but they are far to expensive for my budget. I also was given a pocketbike motor for free, and with the addition of a 3.25:1 reduction gearbox that cost me all of £13 (around $18 i think) delivered it has made it a very viable powerplant for me. As with the clutch I always wanted a centrifugal (I only want brake levers on the handlebars) which this has so that has also been ideal. I would say (having almost no experiance of either) that because of there origins are going to be similarly unreliable but with the saved money from getting a free engine I am planning on rebuilding the engine from scratch with the 52cc bore and stroked crank. On top of that i will port match it and replace all the chinese bearings with there swedish counterparts. | alright, sweet plan what your doing with your motor is exactly what im doing with my 80cc
porting, polish, replacing all screws with high tensile stainless steel alan key bolts, new ngk spark plugs, expansion chamber, all new bearings, new air filter. so you can tell im going to have some fun with this engine.
with your bike have the biggest sprocket you can find on the back wheel so you will have a nice ratio,
YOURS:  MINE:
in the end its about having fun.... and showing off lol
10-22-2009, 08:11 PM
Originally Posted by TorqinDirty with your bike have the biggest sprocket you can find on the back wheel so you will have a nice ratio | Yep i'm running an 9 tooth on the front and a 68 on the rear should be good for around 38mph, might have to experiment though.
Are you planning on taking the bike offroad? |
10-22-2009, 08:15 PM
| | Re: new plans for 80cc bmx with shifter i wouldn't go with stainless bolts. stainless vs. aluminum is a bad combination. the threads of the bolts like to seize, and destroy both surfaces. i've dealt with this a lot. sometimes, you'll be threading a bolt in nice and easy, and it just stops. you try to back it out, and it seizes. it's like the thing was welded in there.
the black, grade 8 allen, cap socket heads are the way to go. they sit flush, they're black, and they'll out last your motor.
also, in my opinion, which i value highly, is use anti-seize compound on everything, NOT loctite. i've NEVER had a bolt loosen up, and they come out when i need them to.
there's been hundreds of threads about loctite, as it's just a great controversy starter. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 10:30 PM. | | | Sponsors
