Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
new plans for 80cc bmx with shifter
Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. I concurr, the only bolts i would use locktite on are the ones holding your discs of your disc brake ...
  #11 (permalink)
Old 10-22-2009, 08:45 PM
Default Re: new plans for 80cc bmx with shifter
I concurr, the only bolts i would use locktite on are the ones holding your discs of your disc brake systems on. Other than that copperslip them all but be careful as it is carcinogenic, if your posh get a PTFE based grease.
  #12 (permalink)
Old 10-22-2009, 09:35 PM
bairdco's Avatar
you can get a cheap anti-sieze, it's uh... Bostick.
the stupidest thing about the whole Loctite argument, to me, is, everything i've ever used it on came right off anyway. i've never had a bolt stuck that i had to use heat to release, never had a bolt that was actually "locked" in the threads, and never stripped any threads because of it. i personally think it's completely useless.
  #13 (permalink)
Old 10-22-2009, 10:30 PM
TorqinDirty's Avatar
alright that was the sortoff bolt i was talking about but im not going to use stainless anymore i have seen them black bolts used quite alot so thanks for the help
I FIX MORE THAN I RIDE
  #14 (permalink)
Old 10-22-2009, 10:33 PM
yeah im planning to take it offroad and maybe jumps, im going to have rubber engine mounts to help with vibrations and hard landings
  #15 (permalink)
Old 10-23-2009, 08:54 AM
I wouldn't recommend rubber mounting the engine, it isn't a comfort cruizer. I would just put up with the vibrations and ride it. You never see motocross engines rubber mounted. Even on on less offroad biased machines like KTM LC4s they don't rubber mount the engine and they are one of the vibeyest engines around. Even ducati road bikes with all there vibes don't rubber mount there engines. rubber will just allow the motor to flex around maybe changing chain tensions etc...
  #16 (permalink)
Old 10-23-2009, 12:18 PM
BarelyAWake's Avatar
Actually it tends to cause engine mount fasteners to sheer and can lead to fuel foaming problems (you mighta reduced the frame vibration you feel - but ya increased the engine's lol) , as well as the engine tends to cut down/through the rubber after a while - letting the engine twist like you just mentioned
Yeah - rubber mounts are terrible lol, seems like such a good idea...
  #17 (permalink)
Old 11-04-2009, 09:13 PM
Are you any further on with the build plans?
  #18 (permalink)
Old 11-05-2009, 12:23 AM
try cement glue it works better than loctite and it will not turn on you
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f36/new-plans-80cc-bmx-shifter-12218.html
Posted By For Type Date
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 10-18-2009 02:41 AM
