Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
My first motor bicycle (project)! Help needed.
Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. Hello all, I am new to the forums and to building these types of things as well. My father recently ...
Old 06-08-2009, 06:57 PM
Default My first motor bicycle (project)! Help needed.
Hello all,
My father recently bought a shiny new Echo weedeater and said I could have his old one. So I got to thinking that it would be cool to put the engine on my bicycle. Little did I know that many people have already done this and it is quite common.
I have taken apart the weed eater and put the shaft in the shed. I have the engine by itself and am not sure where to go next.
I know I need a place to put the engine on my bike, such as a rack or something. I know I need a clutch because having the engine direct-drive to the wheel would cause it to lock up and die (I think).
But, other than some basic knowledge and common sense, I have no idea where to start.
I think the first thing I should get is some kind of shaft from the square slot where the old shaft was. I'm not sure but I think you put a small gear there.
I am the most basic of beginners and any help would be GREATLY appreciated.
Thank you for taking the time to help me .
~ Aaron ~
Old 06-08-2009, 07:22 PM
Default Re: My first motor bicycle (project)! Help needed.
easiest way to do a weedeater engine is to remove the flywheel cover/ pull start, then mount a bike peg on the shaft, where the flywheel is.. mount it on a rack so the peg turns on the tire.. you could also make the engine lift off on a hinge sort of thing.. but just pedeling fast from a standing start will start it up, couple pumps on the primer ball and it'll start, shouldn't need choke.. weed eater engines are not versitile enough to use clutches.
Old 06-08-2009, 07:27 PM
Is the setup you are talking about like the one on this site:
(changed due to spam filter) "bikemotorparts(dot)com"
If so, I was trying to go for more of a chain setup because the ratio of power doesn't look too great on that setup.
I was wondering if you could use a clutch because you could just start it up with the clutch depressed and then slowly let off the clutch until your bike was at speed.
EDIT: I am going to try and get some pictures of the engine and bike I am using.
Old 06-08-2009, 07:50 PM
a weed wacker engine makes less than 2hp.. the scrub wheel riding on the tire makes a good ratio for the engine.. a clutch is possible, but it would be easiest if it was a friction drive, with a scrub wheel.. clutch would just attach from the engine and the clutch to the scrub wheel.. centrifigul clutch would work... theres no way to make a manual clutch work on a weedwacker, it would be to complex to make it practical..
how many CC is the engine?
Old 06-08-2009, 08:06 PM
The engine is a Homelite ST-275. Not sure about the CC.
Here is the bike I am using along with a left/right view of my engine.
my-first-motor-bicycle-project-help-bike.jpg  my-first-motor-bicycle-project-help-engine-1.jpg  my-first-motor-bicycle-project-help-engine-2.jpg
Old 06-08-2009, 09:08 PM
seanhan's Avatar
Look at some of the videos on you tube..
There are some cool weed eater builds and you can see them in action.
I will help you see what needs to be done...
go to youtube and type moterized bikes...
Old 06-08-2009, 09:34 PM
The engine, being a bit older, may be a bit larger in displacement.. probably somewhere around 40cc.. it is probably too old for an EPA sticker which would list the engine displacememt.. I really don't know how you would do a manual clutch.. in all reality, chain drive is impractical for a weedeater engine..
Old 06-08-2009, 09:52 PM
seanhan's Avatar
check out this one !!!
YouTube - weedwhacker, motorized bicycle
  #9 (permalink)
Old 06-08-2009, 11:29 PM
There are a ton of ways to use a wacker engine. This is how the rc folks do it.
Wackerengines
Strip the engine of most EVERYTHING. Remove the bolt that hold the flywheel in place and put on a prpo adaptor or in your case a Foot Peg.
Good Motoring
DeadEye
  #10 (permalink)
Old 06-08-2009, 11:59 PM
Originally Posted by seanhan View Post
This is exactly what I am looking to build. I am just not sure what needs to stay on the engine and what I can scrap.
Someone said take off the pull start, but if I do that how will I start it?
