| | | DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds | My 5HP Project, frame Donated from (Womens Schwinn) Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. i started this today, frame moded, and the motor mounted. If any one has any ideas i would love to ...  |
05-12-2009, 10:03 PM
| | Motorized Bicycle Newbie | | Join Date: May 2009 Location: Haysville, ks
| | My 5HP Project, frame Donated from (Womens Schwinn) |
05-18-2009, 01:37 AM
| | Motorized Bicycle Elite Member | | Join Date: Aug 2008
| | Re: My 5HP Project, frame Donated from (Womens Schwinn) This looks like an AWESOME project!
Disc brake is nice.
i can't imagine why a tank above the engine would cause problems.
A rack-mounted or one above the bar would be okay, I would presume.
What's your driveline gonna be like? No pedals?
05-19-2009, 09:07 AM
| | Re: My 5HP Project, frame Donated from (Womens Schwinn) Thanks!
no Pedals, i just hope i dont break down miles from home.
driveline is going to be belt with a tensioner pully, with a jackshaft then a chain to the rear wheel. |
05-21-2009, 12:07 PM
| | Re: My 5HP Project, frame Donated from (Womens Schwinn) If I were me, I'd do my darnedest to keep the pedals for two reasons:
If engine fails, I can pedal to my destination.
It helps to "ghost pedal" when "Johnny Law" is in the vicinity. |
05-25-2009, 01:25 AM
| | Motorized Bicycle Newbie | | Join Date: Mar 2009 Location: Near Phila. PA.
| | Re: My 5HP Project, frame Donated from (Womens Schwinn) Hi kcbford1,
It looks like you have a diaphram carb on that engine, with the dip tube coming out the bottom. Meaning that, the tank bolted to the bottom of the carb. That tank and carb have to stay together.
You could however, change to a float bowl type carb and mount the tank above the level of the carb somewhere.
The float needle keeps the carb from being flooded. It's a good idea to have a separate shut-off valve on the tank, though.
buzzardbait |
05-26-2009, 10:40 AM
| | Re: My 5HP Project, frame Donated from (Womens Schwinn) thanks for the fuel tank info! | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -5. The time now is 02:19 AM. | | | Sponsors
