Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Mount it sideways?
Discussion at Motorized Bicycle Engine Kit Forum in the DIY Home Built Motorized Bicycle (non kit) forum. Just about the right rpm rating. looks like a hypoid ring and pinion. Available right or left. 1.25 inch ...
Old 08-29-2009, 02:40 PM
Default Mount it sideways?
Just about the right rpm rating. looks like a hypoid ring and pinion. Available right or left. 1.25 inch output shaft! Hacksaw and dremel it down to eight lbs (i'd bet).
128 x 14 equals about 1575 which makes sense as a typical electric motor speed. Have to check with Magnetek about the possibility of running it at three to four times this with a gas engine. That would put the output at about 385 to 500 rpm. At bicycle crankset rpm in the 30 to 100 range this is not out of range for our purposes (if you want to power the crankset like I do).
With any luck that pinion gear is self supported (instead of merely an extension of the motor shaft) and has an easily adaptable input.
LinkBacks (?)
LinkBack to this Thread: http://motorbicycling.com/f36/mount-sideways-10752.html
Posted By For Type Date
Biking Bis - Bicycle Touring and More :: Feed Zone This thread Refback 08-29-2009 07:34 PM
